Hotwire, 450, BAP
Old Oct 3, 2018 | 07:16 PM
rpm-inc's Avatar
Default Hotwire, 450, BAP
2004 Silverado, running out of pump with Walbro 450, Racetronix hotwire, e85, and 13 psi. Anybody running a Kenne Bell 40a boost a pump with this pump and harness?
Old Oct 3, 2018 | 11:14 PM
Last Call's Avatar
TOTM: January 2007
Yes, I was running the 40 amp/17 volt BAP with a Racetronix harness. It took me to about 670 rwhp on E85. I think I could have stretched it to 700rwhp, but not much further than that.
Depending on how much power you want to make, tt would be better to a return style conversion and dual pumps or maybe the new Walbro 525?
Old Oct 4, 2018 | 05:01 PM
rpm-inc's Avatar
I did convert to a return style, -8, -6, regulator after the rails. With my trap speed and weight, I should be right at 600whp. I am thinking that's about max for this pump with e85. I saw a chart a while back that had the 267 pump with higher voltages and I can't find it now. Would like 750whp worth of pump.
Old Oct 5, 2018 | 10:38 AM
Last Call's Avatar
TOTM: January 2007
I think it would be best to go twin pumps, one pump with a BAP on E85 will be difficult.
Old Oct 5, 2018 | 05:56 PM
rpm-inc's Avatar
Yep. I ordred an aem external pump, sump, filter, and all the other stuff. My under the truck spin on fuel filter housing is dual inlet, so should be easy!
Old Oct 5, 2018 | 06:28 PM
arthursc2's Avatar
do you have a link to that filter assembly! Looking for a dual pump situation on my pile for the big motor
Old Oct 5, 2018 | 06:39 PM
rpm-inc's Avatar
I will try to find the part number for the spin on filter housing if that is what you are talking about? It is a napa stock part.
Old Oct 5, 2018 | 07:25 PM
arthursc2's Avatar
Yes I think so, because you said your filter housing was dual inlet. Seems better to me than Y-ing the lines together at the regulator
snogoer
Apr 12, 2018 11:44 AM
FullOutPwr
Oct 24, 2017 12:03 PM
pittman
Aug 14, 2014 07:47 AM
Superado
Aug 26, 2010 09:33 AM
trever1t
Jun 13, 2007 05:37 AM
