Walbro 450 Hotwire kit????
I am looking to buy a Walbro 450 Hotwire kit for my 2009 GMC Sierra or if someone has detail pictures/instructions on how to build one. Tried contacting Racetronix twice now haven’t hear anything back in a week. Maybe someone has the Racetronix part number for Hotwire kit
thanks
thanks
if you click on the link that hutch provided it shows a nice clear picture of the wiring. your fuel hat will have four wire connector to it; power, ground, fuel level + and fuel level -. this hot wire kit uses the factory power signal to trigger a relay which pulls power directly from battery/alternator. in the kit they use factory male/ female connectors to pass the fuel level sensor wires to the computer as well as divert the power wire to the relay. their kit is nice and plugs right in - you just need to verify the connector type that you have on your fuel hat , either the flat four connectors or a square connector. they have kits for both. when i added a second fuel pump i just built my own custom harness.
_zblee
_zblee
the racetronix kit comes with 20a and that should be just fine. a single 450 @ 58psi is only supposed to draw UNDER 17amps so if you blow a 20 amp then there is something wrong ( a good reason why you should not put a 25a fuse )
i have had issue where the fuses on my efans were melting and it was an issue with the fuse holder , not the fuse size.
_Zblee
The harness IS a Racetronix harness. Racetronix told me to use the 25 amp. Gonna go look at the fuse and holder now. Mine was drawing 17 amps. Maybe it spikes at startup. I can check that too.
EDIT-Fuse and holder are fine after a few thousand miles. The 20a fuse and holder had about 10000 miles maybe.
Your explanation makes sense, and is what I originally thought. Fuse should blow before anything melts. I don't know. I talked with racetronix through their online support forum for people who have bought something....Took a while to get approved to post.
if its melting then you need to get a better quality fuse holder. if it is not breaking the fuse then its not drawing more than 20amps...
_Zblee
_Zblee
_zblee
