Fuel pressure woes
Old Feb 17, 2013 | 11:22 PM
  #51
AndysC3's Avatar
Ok, so if I add my 044 intank and leave the 044 inline that will supply enough fuel for 700 wheel hp?
Old Feb 17, 2013 | 11:25 PM
  #52
Mangled03gmc's Avatar
Baltimore Whore
Yeh prob be good for 1000, but im curious where your going to come up with 700whp ?
Old Feb 17, 2013 | 11:26 PM
  #53
AndysC3's Avatar
I may look into that then. What will I need to install it in the tank?
Old Feb 17, 2013 | 11:34 PM
  #54
Atomic's Avatar
I have a gauge for that
The 044 has a very flat pump curve (doesnt change much with pressure), in fact it only drops 13% from 30 to 80psi. So adding a second one will not really help you at all and will just add complication to the system. Keep the 2nd one as a backup.
Old Feb 17, 2013 | 11:38 PM
  #55
Baltimore Whore
Yes but wouldn't more flow = more supply, because of the volume of fuel the 2 are moving ? Same pressure but ultimately more flow//
Again I think 1 intake will be enough for that set up..
Old Feb 17, 2013 | 11:39 PM
  #56
AndysC3's Avatar
So take out the inline pump and put that line back to stock and run one 044? Nothing else?
Old Feb 17, 2013 | 11:41 PM
  #57
AndysC3's Avatar
And a -8an to 3/8" barb?
Old Feb 17, 2013 | 11:44 PM
  #58
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by AndysC3
Using my last track times I'm at about 580-590 to the wheels.
Last I read, you were running 12.7? How is that 580-590 at the wheels?
Did I miss something?
Old Feb 17, 2013 | 11:47 PM
  #59
Baltimore Whore
You need to order the sock for the pump, order a hot wire kit or make your own, about 8'' of fuel injection hose, 2 hose clamps, a barbed fitting to replace the check ball on the pump or a way to use the fitting with the check ball in it.
Old Feb 17, 2013 | 11:52 PM
  #60
AndysC3's Avatar
