Fuel pressure woes
Old Feb 17, 2013 | 10:49 PM
  #41
Atomic's Avatar
I have a gauge for that
My walbro 400s cost $120 each from ebay. Tapping the tank is a bad idea, I dont care how safe you think it is. Dont cheap out and try to do this, you will regret it later when you have to redo it later when it fails. If you dont have the time or money to do it correctly, then dont do it!
Old Feb 17, 2013 | 10:52 PM
  #42
AndysC3's Avatar
I've done a lot of research on it. A lot of the corvette guys tap the rear of the tank. Surperado taped the rear of the tank with two -10 fittings. The tank is actually pretty thick. And I have a 05 jetta that I can drive if needed. The winter will be mostly over when I get there.
Old Feb 17, 2013 | 10:53 PM
  #43
AKlowriderZ71's Avatar
11 Second Hall Moniter
You don't want big ice-***** of slush snow and ice hanging off your Custm fuel system. Winter driving is a bitch.
Not to mention the expansion/contraction of that plastic tank with temperature swings.
Old Feb 17, 2013 | 10:58 PM
  #44
smokeshow's Avatar
Mod with training wheels
It sounds like you're gonna do what you want to do regardless of the advice given here lol.
Old Feb 17, 2013 | 11:03 PM
  #45
AndysC3's Avatar
If someone wants to build me a duel intank pump bucket then by all means I will go that way. But I just don't have the time to do that myself
  #46
Mangled03gmc's Avatar
Baltimore Whore
Pretty much.. You don't tap plastic fuel tanks, fuel cell yes, as it has revisions for fittings, it's not to safe to do. This is like wiping your *** before you ****, makes no sense.. Why are you dead set on 2 pumps ?
Old Feb 17, 2013 | 11:07 PM
  #47
AndysC3's Avatar
A single 044 will only support about 600hp. Using my last track times I'm at about 580-590 to the wheels. So a single 044 will not cut it.
Old Feb 17, 2013 | 11:10 PM
  #48
Baltimore Whore
Really? I find that hard to believe. I am making well into the 600 range, have never had a issue with fuel for 5 + years of this pump. Guys making 500 on 255's with no problem.. Russ is making as much if not more, as well as Josh, they have not a single issue
Old Feb 17, 2013 | 11:13 PM
  #49
Atomic's Avatar
The 044 will flow more by itself than the setup you have now with it pulling through the 255. If you dont believe me, read my sticky in this section and use my spreadsheet and look at the pump curves. Keep in mind in a series setup, flow is limited by the least flowing pump.
Old Feb 17, 2013 | 11:18 PM
  #50
Baltimore Whore
YUP..
Also with Russ and Josh I am pretty sure they were running on the STOCK wiring, not the big gauge kit which just by it self will allow the pump to work more efficient.
