Fuel pressure woes
Old Feb 24, 2013 | 03:26 PM
  #141
03sierraslt's Avatar
Ensure a good connection at all terminal ends, if in doubt add some solder. I add a bit of solder after crimping anytime I modify any of the factory wiring. You would be amazed at how little it takes to impede the flow of current. I have seen some crazy things with wiring cause issues.
I have a A&P license along with that comes certification to wire aircraft, just so you know I am not speaking from 2nd hand info.
Old Feb 24, 2013 | 06:31 PM
  #142
AndysC3's Avatar
Okay. The terminals have a good connection. I'm going to try and fix the ground. That may be my issue. Hope it is. I may add that second 044 inline to help keep the pressure up
Old Feb 24, 2013 | 06:34 PM
  #143
It is my opinion that doing so will only band aid the issue that you are having.
Old Feb 24, 2013 | 06:37 PM
  #144
AndysC3's Avatar
Then what should I do?
Old Feb 24, 2013 | 06:45 PM
  #145
Well, like Roger said something else is going on. Voltage drop at pump is also my guess, the ground would be a good place to start IMO. There is no way you should be seeing a pressure drop like that nor a IDC that high with those injectors, you are not moving enough air for that amount of fuel. Hell with a good fuel supply 60's will support that without a issue.
Old Feb 24, 2013 | 07:08 PM
  #146
AndysC3's Avatar
Okay. I start on the ground and see if that helps. I also retuned and took out some fuel to get the afr back to 11.5. Should help some
Old Feb 24, 2013 | 09:20 PM
  #147
AndysC3's Avatar
If I get a walbro 450, can I run that and the walbro 255 that I had in the tank together? With one of them on a Hobbs?
Old Feb 24, 2013 | 10:02 PM
  #148
AKlowriderZ71's Avatar
11 Second Hall Moniter
Why not just fix what you already have? You have good fuel system components. That isn't your issue. They need to be installed properly. Stop neglecting your electrical system, it's much more important than you realize. (Or so it seems.)
Old Feb 24, 2013 | 10:14 PM
  #149
AndysC3's Avatar
Okay, I'll fix the ground and tighten/loosen the fpr and see if that helps.
Old Feb 24, 2013 | 11:56 PM
  #150
AndysC3's Avatar
I upgraded the ground to a 12ga and is attached to the frame right next to the tank.
