Fuel pressure woes
#141
Ensure a good connection at all terminal ends, if in doubt add some solder. I add a bit of solder after crimping anytime I modify any of the factory wiring. You would be amazed at how little it takes to impede the flow of current. I have seen some crazy things with wiring cause issues.
I have a A&P license along with that comes certification to wire aircraft, just so you know I am not speaking from 2nd hand info.
#142
Okay. The terminals have a good connection. I'm going to try and fix the ground. That may be my issue. Hope it is. I may add that second 044 inline to help keep the pressure up
#143
#145
Well, like Roger said something else is going on. Voltage drop at pump is also my guess, the ground would be a good place to start IMO. There is no way you should be seeing a pressure drop like that nor a IDC that high with those injectors, you are not moving enough air for that amount of fuel. Hell with a good fuel supply 60's will support that without a issue.
#148
Why not just fix what you already have? You have good fuel system components. That isn't your issue. They need to be installed properly. Stop neglecting your electrical system, it's much more important than you realize. (Or so it seems.)
