fuel injector help for H/C/I/E Procharged 6.0
Old Jul 9, 2012 | 07:03 AM
  #71
AndysC3's Avatar
Got it mostly figured out. Going to go with the left setup in the above pic. My question now is to run a -6 line all the way back or use the stock feed line. Found a hobbs switch that you can adjust from 1-6 psi that I will use to turn the second pump on. Will I need a check valve for that pump?
Old Jul 9, 2012 | 08:35 AM
  #72
Atomic's Avatar
I have a gauge for that
Yes that will be fine...the stock line is 3/8 so its basically a -6 already.
Old Jul 9, 2012 | 08:38 AM
  #73
AndysC3's Avatar
ok, Thanks. Should I reverse the fuel filter since its suppose to flow one way?
Old Jul 9, 2012 | 08:47 AM
  #74
Atomic's Avatar
Oh, I forgot you have a return system to start with....in that case, it may be better to run a new line or some how get rid of the filter. You dont need or want it on the return side.
Old Jul 9, 2012 | 10:21 AM
  #75
AndysC3's Avatar
ok. Ill look into it. Any idea what the thread size is for the filter. If there's an issue I should be able to use a y and use both the return and the feed to return teh extra fuel lol. Thanks
Old Jul 9, 2012 | 10:29 AM
  #76
AndysC3's Avatar
also, where should I Y the two lines from the bumps together? Does it make any difference?
Old Jul 9, 2012 | 11:20 PM
  #77
AndysC3's Avatar
Atomic, didn't you have to run some spacers on your injectors? Do you think I'll need some with an aftermarket fuel rail? The fast 65# are about 5mm shorter than my stock injectors. And if so where did you get them?
Old Jul 10, 2012 | 12:39 AM
  #78
Atomic's Avatar
Dunno why I didnt think of it, but since you are currently return-style, you can just reuse the stock return line. I believe its 5/16" which should still be alright.
It doesnt really make a difference but I would tie them together as close to the tank as possible to simplify installation.
I had to space the injectors and the rails due to how the L92 intake rail mounts are. It is best to mock everything up on a table and measure to see. I got mine from FIC.
Old Jul 10, 2012 | 12:44 AM
  #79
AndysC3's Avatar
Ok, I'm running the tbss intake now. Don't really have extra time to mock everything up. I may go ahead and pick some up just in case. Thanks.
Old Jul 12, 2012 | 10:14 AM
  #80
AndysC3's Avatar
OK, Im going to pick up the fuel rails today. Im undecided between these two. The ebay ones have the crossover and fittings, but I know the Edelbrock will take me as far as I need.
LS1 / LS6 Fuel Rail Kit | eBay
Autoplicity.com. Edelbrock Fuel Rail Kit Chevy LS Series - 3629
