E85 kits?
Old Jan 24, 2018 | 07:50 PM
Sawyercat's Avatar
Registered User
Default E85 kits?
i have a 1999 GMC Sierra with a cammed 5.3 and I wondering if there are any companies that sell E85 kits.or what would I need. I know I’ll need new injectors, fuel pump, new lines, pcm flash. Would I need anything else, where would I get everything
Old Jan 24, 2018 | 08:02 PM
FFDP's Avatar
Just a pump, injectors and a tune is required. The factory fuel lines are metal, you don't have to replace them and they will flow way more fuel than you would require on a cammed engine.
Old Jan 26, 2018 | 12:39 PM
About20ninj45's Avatar
Filler neck isn't, on mine at least anyway.
Old Jan 26, 2018 | 01:07 PM
arthursc2's Avatar
Why would the filler neck matter?
Old Jan 26, 2018 | 04:03 PM
Rubber may degrade over time or may not be able to handle it
Old Jan 26, 2018 | 04:29 PM
arthursc2's Avatar
Show me a documented case and I'll believe it
Ive run e85 on a '93 Saturn system, bone stock everything except a 255, never an issue
I run e50 in a '91 MR2, completely stock everything and its been fine
I dont buy the hype of "e85 and incompatible materials." How many parts do you clean with rubbing alcohol/IPA, and never had an issue? I let e85 sit in a plastic bottle in my hot *** shed for well over 2yrs, and the bottle was still fine and pliable, and we still use that bottle for oil and trans fluid capture.
bigsapper
Jul 1, 2013 07:16 PM
centexz99_z71
Nov 9, 2010 05:19 PM
Rumble Bee Ram
Jul 17, 2005 09:31 AM
FastCarsSpeedKills
Dec 18, 2004 10:36 AM
cstchevy
Feb 27, 2004 02:41 PM
