Dual pump build ?
#41
P.S. I like this also. Yea its extra money but i drive my truck 260 miles to work one way... Right now i dont stop for gas until i get there... After i swap to a dual setup i would have to fuel up sooner. Especially if i swap to e85. What's a few hundred bucks up front to be able to have peace of mind and not worry about fuel starvation.
My cons
1. I am going to use my factory return fuel lines so i would run new fuel lines with this set up....
2. If the tank pump gives out then it's down. With 2 intank pumps, i can run low boost and still drive the truck on the second pump if one goes out.
#42
Ahhh i just watched the video.... Now i see that it returns to the surge tank... then returns to the gas tank. Nevermind, carry on....
My cons
My cons
I want to get some input from someone running a surge tank to see how well it works.
#43
How many internal pump failures have y'all seen? I've seen one external pump on my dodge fail. This case was clearly a design flaw in the system. The dodge Cummins had pumps on the back side of the motor pulling from the tank. They dont support that pump at the dodge house any more and have to do a conversion to an in tank set-up. I guess what I'm getting at, if your system is up to the task, your not going to over work it and the pump failure rate is extremely minimal if your not cavitating it. I believe this is starting to get over thought a little. Get those pumps and Venturi in there somehow and run it.
#45
Nice unit.
How big is it? There is nothing in the picture to reference size. We can't give you ideas where to put it without knowing how big it is.
My home made one is mounted in the front left of the bed, near the fuel tank pump. That was easiest for me to reroute the lines from the tank, out through the frame rail, up between the bed and outer body, and then through holes in the side of the bed.
#46
MPFST Dimensions
Body Outside Diameter: 6 inches
Height (not including fittings): 8.9 inches
Mounting base bolt circle diameter: 6.5 inches
Mounting base maximum outside diameter: 7.1 inches
Working internal fluid volume (with 2 pumps): 2.0 liters
#47
I would say under the truck on the frame where (on my truck, anyhow) the stock fuel filter is. Unless you live in the rust belt. It still looks sturdy enough to mount there anyway. Really, it seems small enough that you could mount it wherever is easiest for you to run the lines.
#50
I figured it would save me the hassle of building the Y and the pumps are already secured some. Also only a little more then the pumps themselves cost. Not sure where im going with this yet.
https://www.maperformance.com/produc...FZu3wAodRdsJ5w
