08 GMC Denali 6.2 fuel pump
Old Feb 4, 2019 | 05:27 PM
121's Avatar
121
Default 08 GMC Denali 6.2 fuel pump
Can anyone chime in and give me some advice.. 2008 GMC 1500 6.2 AWD none flex fuel and there is no fuel pressure control module. Can I put a Walbro 450 in the tank and use the stock lines and fuel rails with 80lb injectors?
shooting for 10lbs with e85. The truck has a trick performance kit with a 78/75 turbo.
Any help is very much appreciated!
Old Feb 4, 2019 | 05:34 PM
FFDP's Avatar
Seems like it would work.
Might need a better pressure regulator because that pump flows a lot of fuel.
Old Feb 4, 2019 | 05:44 PM
121's Avatar
121
Would I be better off with a 255?
Old Feb 4, 2019 | 05:57 PM
FFDP's Avatar
255 won't be enough for E85.
Shoot for a power level not a boost level and then see if you have enough pump and injector to support that.
Using a calculator you'll need over 300-320lph on E85 if you plan to make 550-600hp. Which should be fairly easy to make on a 6.2.
Old Feb 4, 2019 | 06:07 PM
121's Avatar
121
That’s where he wants to be so that’s why we picked a 450lph. We are trying to keep most things stock as possible. My buddy is competing against his brother in Rocky Mountain drag week this coming summer. So I’m trying to line it all out for him lol They are just doing it for fun.
Old Feb 5, 2019 | 11:31 AM
RySmDPT14's Avatar
The 450 works, but it overpowers the stock regulator. I was getting 75 psi at idle (commanded 58) and it wouldn’t run right. Others have seem to have better luck on stock set ups with the 450 than I did. however, ended up Taking the pump assembly apart and threw in the hellcat pump with an aeromotive regulator.
Old Feb 6, 2019 | 03:01 PM
121's Avatar
121
That’s what I was worried about. I definitely don’t want any problems. When you put the hellcat pump in what did you do for the return line?
Old Feb 6, 2019 | 03:04 PM
RySmDPT14's Avatar
The factory feed line worked as a return which I let dump right into the bucket.
Old Feb 6, 2019 | 07:44 PM
121's Avatar
121
Perfect! Thank you for the help
About20ninj45
Oct 13, 2017 05:23 PM
chaselanesmith
Jun 19, 2010 12:23 AM
walledition
Nov 5, 2009 10:32 AM
NegraRCSB2X4auto
Jan 2, 2009 08:33 PM
BigMike9009
Dec 6, 2005 07:25 PM
