Whipple supercharger concerns.
Old Feb 10, 2012 | 12:15 AM
  #31
Stimpeee68
If you have a 3 3/8 or 3 1/2 pulley for id be interested!
Old Feb 10, 2012 | 12:25 AM
  #32
Stimpeee68
Old Feb 10, 2012 | 09:52 PM
  #33
bowsman's Avatar
I got with Stimpeee68 and he gave me a good deal on buying 5 pullies from him. 2-7/8, 3, 3-1/8, 3-5/8, 3-3/4 so 25004x4 let me know if you want to experiment with any of them once you get yours. I was wanting to wait til next weekend to start mine but I think I am gonna get out into the garage tonight and start takin it apart.
Mine didnt come with any bolts so I am sure I will be running out a few times to try and find the right ones.
You got any measurements on the bolt going through the lower pulley thats mounted in the slot on the lower plate? I am assuming there is just a big washer and locknut on the backside in the recessed part. Is that correct?
Also wondering what you were planning on doing with the boost bypass and vac lines.
Old Feb 11, 2012 | 02:44 AM
  #34
I was gonna start putting it on tonight but i wasnt sure on a few things like the oil filler neck? do you take it off and get a differ one? the dipstick? Is there any clearance issues with the heater hoses coming out of the firewall? Anybody have install directions they could post!
Thanks
Pax
Old Feb 11, 2012 | 10:20 AM
  #35
MikeGyver's Avatar
Remove the oil filler extension and put the cap directly into the valve cover. Then switch driver's and passenger side valve covers.
the dipstick?
Whipple instructs to bend the dipstick tube so that it ends up between the throttle and firewall. It is very difficult to bend enough without kinking it, I suggest rotating it in the engine block so that it is outboard of the blower. Then figure out a new way to attach it. It wouldn't hurt to have a new spare tube on hand, they are easy to snap off in the engine.
No.
Thanks
Pax
You're welcome.
Old Feb 11, 2012 | 10:59 AM
  #36
bowsman's Avatar
MikeGyver
Any input on what to do with the vac lines? I believe they are for the boost valve. Both of us are removing the whippletronics and going with bigger injectors and a tune. I have read others removing and plugging one of the hoses. I would rather remove as much of the setup and plug the ports before mounting the setup if possible. It looks like its gonna get burried under there once its mounted.
Old Feb 11, 2012 | 11:05 AM
  #37
bowsman's Avatar
25004x4
What is your email. I have a PDF of how to install this for a 1999. From reading it over, its pretty much the same but its the best I could find. I dont know how to post PDF'f on here but I have it saved to my computer and can email it to you.
Old Feb 11, 2012 | 11:19 AM
  #38
MikeGyver thank you very very much!!!
Bowsman i was thinking about putting it in today but i dont got the tune or anything yet.. is it a pain to get the whippletronics off once its installed? and i dont got any gauges yet.. mabey its dumb to put it on now.
and my email is paxtonlee17@gmail.com
Pax
Old Feb 11, 2012 | 03:15 PM
  #39
bowsman's Avatar
From what I have read, everyone doesnt suggest installing the whippletronics because you have to splice into the factory wires and the injectors are a pain in the *** to get to on the passenger side. I would almost guarantee a few weeks of down time for testing and tuning once we do start.
I did get ahold of BlackBear and he suggested the AutoCal tune. Maybe I am misreading it, but that tune doesnt include lifetime retunes. I know this is gonna be a trial and error upgrade so I was hoping to be able to have access to as many tunes as it takes to get it dialed in right. Maybe I need to look harder around me for a local place to do the tuning work.
Anybody got any suggestions for tune shops in the Atlanta Georgia area?
Old Feb 11, 2012 | 03:43 PM
  #40
Bama2door's Avatar
I'm about to put a Kenne bell twin screw on my '04 2500 and it sounds like the instructions are very similar. I have a 125pg booklet from Kenne bell if one of y'all wants to borrow it. I'm hoping to start my install in the next couple weeks. I still need to order a few small things. I'm in Tuscaloosa if anyone wants to have an install weekend and we can help figure everyone's out....
