Whipple 2.9L on a truck
#45
Whipple makes 2 lower manifolds for the 2.9 I have the" Camaro kit" on my hoe with L 92 heads but i run the truck acc drive we machined 1/2 inch off the back of the alt brkt and bolted a plat to the motor that is drilled and tapped to move the alt brkt to the driver side so it clears throtttle body they flip it over to clear the shaft and pulley
#47
Also, how does this alter the throttle body position in relative to factory? Could an intake designed for the factory intake manifold still work or does the throttle body position change too much for that?
#48
For what its worth I posted this write up a few months back on how i installed the 2.9 on my 2003 6.0 Escalade. The 6.2 should be basically the same setup. It's not undo-able it just takes a little self engineering and fabricating .
https://www.performancetrucks.net/fo...-6-2-a-494972/
#49
