Whipple 2.9L on a truck
Old Jul 29, 2012 | 06:03 AM
  #41
rjwz28's Avatar
Man Motor club
Hmmm...
That doesn't sound bad at all; I may have to look into this
Old Jul 29, 2012 | 08:13 AM
  #42
Gadgetized's Avatar
What kit are you actually using?
Old Jul 29, 2012 | 09:37 AM
  #43
03sierraslt's Avatar
I was under the impression it was the 2.9 Camaro Kit.
Old Jul 29, 2012 | 03:50 PM
  #44
rjwz28's Avatar
Man Motor club
According to his first post it is a "camaro tuner kit with the cathedral port intake manifold"
Old Jul 29, 2012 | 10:27 PM
  #45
PRO TOUR HOE's Avatar
Whipple makes 2 lower manifolds for the 2.9 I have the" Camaro kit" on my hoe with L 92 heads but i run the truck acc drive we machined 1/2 inch off the back of the alt brkt and bolted a plat to the motor that is drilled and tapped to move the alt brkt to the driver side so it clears throtttle body they flip it over to clear the shaft and pulley
Old Jul 30, 2012 | 05:03 AM
  #46
rjwz28's Avatar
Man Motor club
Is that the only modification necessary to run it with the truck accessory setup? Is there any accessory difference between your truck and the GMT900 pickups?
Old Jul 30, 2012 | 06:45 AM
  #47
rjwz28's Avatar
Man Motor club
Also, how does this alter the throttle body position in relative to factory? Could an intake designed for the factory intake manifold still work or does the throttle body position change too much for that?
Old Jul 30, 2012 | 09:15 PM
  #48
03SuperSLADE's Avatar
For what its worth I posted this write up a few months back on how i installed the 2.9 on my 2003 6.0 Escalade. The 6.2 should be basically the same setup. It's not undo-able it just takes a little self engineering and fabricating .
https://www.performancetrucks.net/fo...-6-2-a-494972/
Old Aug 1, 2012 | 03:02 PM
  #49
MoeDenali's Avatar
What is the belt length you are using with your setup?
Old Aug 1, 2012 | 03:39 PM
  #50
Gadgetized's Avatar
Man that looks nice. Is the 6 rib holding up OK?
