whine n' a whistle
Old Jul 1, 2010 | 10:52 PM
  #51
smokeshow's Avatar
Mod with training wheels
better boost video
Old Jul 4, 2010 | 05:15 AM
  #52
fastnblu's Avatar
Originally Posted by skolman91
...looks like you have it pretty well figured out but i just have one question, would'nt it be better for the bypass to open a little later like around 6-7 turbo psi intstead of 3.5psi? i mean to take full advantage of the blower low end power (which is making around 7psi max correct?) and then have a smoother transition i would think into the turbo top end power? just thought id ask..?
I'd wondered the same, but figured OP would post up sooner or later on that.
Originally Posted by anasasisxenophontis
Well I certainly learned something today. I guess the orientation of the MAF sensor can affect performance. Not direction of flow, but literally rotation away from where the sensor was at in its stock configuration. It caused the MAF to report more air flow to the engine when there actually wasn't excess flow, so it ran extremely rich. Still more kinks to work out in the tune, but it pulls a hell of a lot harder now.
Kudos go to Justin at Blackbear for that tip.
How would I know where stock orientation of my MAF was? Know that I've put my CAI on & off a few times? Does it matter which direction MAF is twisted, or does going 1 direction instead of other produce a better result?
Or is it more the actual distance?
Interesting.
Old Jul 4, 2010 | 11:43 AM
  #53
smokeshow's Avatar
Interesting.
It just can't process air flow that is not perfectly straight through the sensor. I had pictures of where the stock MAF position was, but since the shape of the intake has changed it really doesn't matter now.
Still working on the running rich issue...
Old Jul 5, 2010 | 02:04 AM
  #54
smokeshow's Avatar
Got the wideband installed with the door gauge mount from 2007chevy5.3l. I think it looks pretty slick
Old Jul 5, 2010 | 06:55 AM
  #55
When do you plan on taking it to the track?
Old Jul 5, 2010 | 11:26 AM
  #56
smokeshow's Avatar
When its running a LOT better lol
Old Jul 5, 2010 | 11:46 AM
  #57
TIM Z's Avatar
11 sec. Truck Mod
You NNBS guys are lucky to have a cool Door guage mount.
Those three gauges look great in that orientation, lots better than a 3 pillar pod.
Old Jul 5, 2010 | 11:36 PM
  #58
smokeshow's Avatar
Here's a video of the AFR. Still trying to work out the bugs
Old Jul 8, 2010 | 01:41 AM
  #59
ChevyTruck's Avatar
something else
Any new updates on this thing?
Old Jul 8, 2010 | 02:04 AM
  #60
Dewey's Avatar
Interesting.
the stock location of the MAF sensor is ~ 4 inches or so from the airbox, and the sensor should be positioned with the plug and bottom piece from the pic below facing up.
