whats holding ur heads down?
Old Feb 19, 2009 | 05:02 PM
TURBHOE's Avatar
Default whats holding ur heads down?
who's useing arp studs who's using arp bolts and who'd got the stock torque to yeild guys hanging out?
will stock gm bolts hold 15psi with a tc78??
Old Feb 19, 2009 | 05:36 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
arp L19's here, over-torqued 15 ft/lbs
Old Feb 19, 2009 | 05:44 PM
Mangled03gmc's Avatar
Baltimore Whore
I would go with atleast arp bolts..
Old Feb 19, 2009 | 05:59 PM
parish8's Avatar
single digit dreamer
stock in the fairmont, heads have never been off. hundreds of runs in the 500-600rwhp range(13-14psi).
i wouldn't change them just for the sake of changing them. if the heads are off any you need now bolts anyways then i would go with the studs.
Old Feb 19, 2009 | 07:58 PM
TURBHOE's Avatar
well i have to pull them off to change lifters. i also think my passenger side head gasket is gone. block on that side is wet and the reservoir is about empty. its been getting lower and lower over the past 2 months. i'm going with the 3 layer gm gaskets. i was wanting to run the 5 layer set up but i think the 4.1" bore might be a bit big.
Old Feb 19, 2009 | 08:09 PM
kbracing96's Avatar
I put studs in my LS1 motor. I pushed water with my stock 4.8 at 14psi with a really rich E85 mix and too much (23*) timing.
Old Feb 19, 2009 | 08:13 PM
parish8's Avatar
why are you changing lifters? hard to beat the stock ones.
TURBHOE's Avatar
Originally Posted by kbracing96
I put studs in LS1 my motor. I pushed water with my stock 4.8 at 14psi with a really rich E85 mix and too much (23*) timing.
well you have a pm. if i'm gonna do it i want to not do it again.
Old Feb 19, 2009 | 08:16 PM
TURBHOE's Avatar
because of this http://videos.streetfire.net/video/t...4-8dafc79eb310
its abit noisy.
Old Feb 19, 2009 | 08:47 PM
ducky's Avatar
im running stockers on 12psi
