whats holding ur heads down?
Old Feb 20, 2009 | 08:08 PM
ONLYA4.8L's Avatar
Me too.. Stock...
Old Feb 23, 2009 | 12:04 AM
stock48's Avatar
9 Second Truck Club
My 6.0L LQ4 pushed water with the TTY's after ~3months daily driven 14~15psi.
Old Feb 23, 2009 | 07:00 AM
TURBHOE's Avatar
i wonder on the stock head bolts that hold and the ones that don't who's has stock mls gaskets and who has stock graphite gaskets?
Old Feb 23, 2009 | 08:56 AM
kbracing96's Avatar
I have stock MLS on both the 4.8 and the LS1
Old Feb 23, 2009 | 09:50 AM
silver-mod-o's Avatar
Hunt&Fisherator
Factory MLS gaskets and ARP studs under the WCCH heads on my 347...
Old Feb 23, 2009 | 10:21 AM
TURBHOE's Avatar
where is the cheapest place to get the studs?
Old Feb 23, 2009 | 06:19 PM
Mort's Avatar
Me to on my 365 LS SB.....by Rex
Sorry Rex supplied mine and I have no idea of the best place to get them.
Old Feb 23, 2009 | 08:55 PM
Inspector12's Avatar
TT-TECH Veteran
APR regular studs have been good for me up to about @15 lbs. APR2000s good for more LOL! @23lbs L19's are a little stronger, but they are not intended for long term use because of there corosion properties. I used them without issues, but I didn't have them on but for a little over a year so. My recomendation is depending on what you are planning to do. 15lbs standard ARP's more I'd go for the ARP 2000 material and just about as strong as the L19's. As far as the gaskets I used them all the best are the MLS gaskets the 3layer ones were good the 5layers are supposed to be better, but can't confirm if they hold better or not yet only that GM designed them for the ZR1 put 25% stonger fasteners and heads made from better/ harder material on them so who knows. The bigger bore on your motor is not an issue to me, but your choice. GL!
Old Feb 23, 2009 | 10:46 PM
SincalT/A's Avatar
Stock tty bolts here.
I am beginning to push water @12 psi.
I also need a retune and believe that would help.A good tune goes along way when you get in the ballpark of pushing water.
It is prolly to late for me but I will try some arp's to see if they help.I am sure my gaskets have took a pretty good beating by now.
Old Feb 24, 2009 | 10:21 AM
TURBHOE's Avatar
inspector12. i looked at the gm 5 layer but everyone i talked to said not to use the 4.1" bore gasket on a 3.778" bore like we have. is there a huge price diff between the types of studs?
i got the turbo and mainfold off last night. i need to drain the coolant to take off the head. its so stupid cold outside here and windy too!!!!
