what size turbo ?
Old Jun 15, 2011 | 04:49 PM
01GMC5.3's Avatar
Default what size turbo ?
alright fellas I am joining the darkside and need some help. I have an Lq4 bottom end with P&P ls3 heads and I was wandering what size turbo to go with? this is going in a mustang with an 80e behind it. its not going to be driven everyday and im going to stick with the stock bottom end right now. also after I get the turbo I will be gettin a custom cam for it also. So what do yall think ????
Old Jun 15, 2011 | 05:26 PM
slowlsx's Avatar
you might want to go over to ls1tech... plenty of builds just like yours in the forced induction section! but if your on a budget i would go with a s480! good for 1300hp and will give you room to grow later on.
Old Jun 15, 2011 | 05:33 PM
smokeshow's Avatar
Mod with training wheels
What are you going to use the car for...? Weekend warrior, or track only type?
Old Jun 15, 2011 | 07:40 PM
01GMC5.3's Avatar
actually a little bit of both
Old Jun 16, 2011 | 08:23 AM
M&M Turbochargers's Avatar
prob something in the 76ish inducer range
Old Jun 16, 2011 | 10:08 AM
kbracing96's Avatar
How much power? What are your goals for the car? How do you want it to drive on the street? How much do you want to spend? All needed info when choosing a turbo.
If you say 1000hp and instant spool on the street, I'm going to kick you in the shin!!,
Old Jun 16, 2011 | 05:41 PM
sprayedenali's Avatar
s400 series!!!! good little, actually theyre huge, turbos!
Old Jun 16, 2011 | 10:06 PM
01GMC5.3's Avatar
holly **** mitch you were not kidding that is a huge turbo!! im thinkin about going with a gt45 what you think ?
Old Jun 17, 2011 | 03:44 AM
kostelacd69's Avatar
Old Jun 17, 2011 | 08:21 AM
01GMC5.3's Avatar
Originally Posted by kostelacd69
I have a gt4508R on a 402 with 9.3to1. 1.15 ar with a 80e behind it. The compressor map on it is great for a 370 inch motor, its a perfect match. from 6psi to 20psi. Even on my 402 is great. Was running the s400 stuff for awhile. great budget turbo but doesnt compare to the 45. just my .02
Thank you sir !
