what kind of hp. gains will I get
Old Sep 30, 2014 | 07:21 PM
Default what kind of hp. gains will I get
right now..... 512rwhp 514tq
sbc 355 mpfi
3.10 pulley on a ati-procharger (15psi@6000rpm)
62# injectors
1.5 rockers with .510 gross lift on a 8-305-8 comp cam
next upgrade, same motor and cam
2.65 pulley
80# injectors
upgraded valve springs to dual spring for .544 lift
1.7 rockers
what kind of gain will I see....what's your two cents
Old Sep 30, 2014 | 08:02 PM
blown02408's Avatar
02 w/ lowest mileage 2800
If your running a p1sc or 600b you've probably made as much power as your going to make. The smaller pulley is only going to chop the air up, cause more heat, and belt slip on one of the above procharger models. The power band might come on as much as a 1000rpm sooner though, but fall off on the big end.
Old Oct 1, 2014 | 06:22 AM
I am running a d1-sc and have modified the belt system for 0 slippage...I will also have to add a 3 bar map
Old Oct 1, 2014 | 08:41 AM
Vortec350ss's Avatar
I would think about a larger crank balancer before I went to a pulley that small. On a procharger thats really small. Unless you already have...
Do you ever run this thing at NED?
Old Oct 1, 2014 | 07:03 PM
no, haven't gone to NED yet....need a better driveshaft, a second loop near the rear end, a better way to evac crankcase...but I am working on it....not a bad idea...the larger crank pulley...thanks
Old Oct 2, 2014 | 12:33 AM
Blown06's Avatar
8 Second Truck Club
I'm gonna doubt success with that pulley on a d1sc as well. Prove us wrong!
Old Oct 2, 2014 | 06:50 PM
I will post up when all the parts go in.....going to try the smaller pulley first with a little back yard engineering
Old Oct 7, 2014 | 08:07 PM
well off to the machine shop with the new plans for the new pulley and idlers...came up with a better way to run the belt .. it should work much better.... will post pics when I get it in
Old Oct 30, 2014 | 09:29 PM
well I got the pulleys back from the machine shop. 320 bucks for a 2.65 and 2 idlers....and figured out how to run the same belt and get good pulley wrap....in all my setups, I have never had belt slippage. I found out that by increasing the base fuel psi 5# should cover the hp gains, so no injectors needed for this round of mods...decided again rockers for now...I will get pics up as soon as I can
Old Nov 2, 2014 | 08:31 PM
had to go with a smaller belt only because I also did a factory bracket dual alternator setup...I happened to have an extra 160 amp hanging around with a couple trips to the junk yard I was able to put it together...will post up pics when I get the 3 bar map installed
