Weird AFR change...
Old Aug 4, 2012 | 03:45 PM
urdone's Avatar
Default Weird AFR change...
Well how the tittle says my air fuel change out of no where.
My truck is a 2010 5.3 single cab with a t76 mm turbo kit with 6 lbs of boost from trickperformace. Well i had it dial in close for my WOT part air fuel was around 11.4 and at 80mph+ AFR was at 11.2 timing at 9* 10*
So i was like im going to bump it up to 11.4 at top, so i took off from 10 miles i was going at it and out of no where my truck bog down I had my eyes all the time at my AFX wideband and when it bog down airfuel jump to 14.3 so i let go real quick. I though it will be gas since i was almost empty but next day i pump gas and try it out now from a dead stop or any roll my airfuel its way lean i cant think what happen i had it real good.
I check for a boost leak everything is good.
Old Aug 4, 2012 | 04:50 PM
AndysC3's Avatar
did you change anything in the tune? what fuel pump and injectors are you running?
Old Aug 4, 2012 | 04:56 PM
urdone's Avatar
No i didt change nothing, im running 52 lbs inj with stock fuel pump (flex fuel)
Old Aug 4, 2012 | 04:57 PM
AndysC3's Avatar
who tuned it?
Old Aug 4, 2012 | 05:07 PM
urdone's Avatar
Im tuning it.
Old Aug 4, 2012 | 05:09 PM
urdone's Avatar
Ok ok, Im looking at my ligs and its not entering PE at wot.
Old Aug 4, 2012 | 05:11 PM
AndysC3's Avatar
what software are you using to tune? post your tune and some logs so we can help you out.
Old Aug 4, 2012 | 05:22 PM
urdone's Avatar
Hptuners.
Let me try to post it up because last time it didt let me.
Old Aug 4, 2012 | 05:24 PM
urdone's Avatar
Heres a small log i did yesterday.
File Type: hpl
Old Aug 4, 2012 | 06:04 PM
AndysC3's Avatar
Log your commanded fuel ratio. and it looks like you only went to 84% TPS. Make sure you enable PE ealier. around 50% throttle.
