Water pump pulley fell off
Old Dec 2, 2012 | 06:54 PM
sharpshooter's Avatar
Default Water pump pulley fell off
Has anyone been able to get one back on while the pump is still on the engine?
Old Dec 2, 2012 | 06:57 PM
03sierraslt's Avatar
Good Question, I know this.. If you do make sure you weld that bastard once its back on.
Old Dec 2, 2012 | 07:12 PM
phasemaster1's Avatar
I dont think you can press it while on the truck. I understand to press it back you need to remove rear cover and support the shaft with socket so it dosent press through.
Old Dec 2, 2012 | 07:23 PM
I have an extra water pump from one of my 6.0 swaps,that I'll put in. It will be welded before it goes in!
Old Dec 2, 2012 | 07:44 PM
TIM Z's Avatar
11 sec. Truck Mod
Yup weld that bitch on ! Wrap the pump with. Cool wet rag while you do it .
I did mine before it walked off , heard bad things could happen.
Old Dec 2, 2012 | 08:16 PM
I have a 120v mig at my house but would tig be better for this?
Old Dec 2, 2012 | 09:25 PM
Tig would be better. But you should be able to with the mig just crank the temp on it since its a 120v. Dont for get to use the wet rag to keep temp down.
Old Dec 3, 2012 | 06:50 AM
dick_landy's Avatar
After I pressed mine back on I used a mig and put 4 spot welds on it. Hasn't moved since.
Old Dec 4, 2012 | 04:04 AM
Originally Posted by Johnmishi
I don't think you can media it while on the vehicle. I comprehend to media it back again you need to eliminate back again protect and assistance the base with plug so it dosent media through.
murderedSS
27
Oct 12, 2015 11:13 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Justin87gn
Sep 10, 2015 12:06 PM
InsaneDomestics
Sep 10, 2015 05:32 AM
mr03silverado
Sep 2, 2015 11:43 PM
