Want to run stock airbox
Old Mar 14, 2013 | 07:28 PM
LsF-150's Avatar
Default Want to run stock airbox
2006 with a KB set up and a Magnum 72, what elbow set up works for connecting to the stock airbox? The turbo inlet sets below the airbox outlet on my truck. Over the years I thought I remembered seeing a few set-ups like this but now I want to see some pics and having a hard time finding any, pretty much everyone runs a 90/open element set-up.
Old Mar 14, 2013 | 07:51 PM
LsF-150's Avatar
Some pics [/IMG]Name:  Airbox2.png
Old Mar 14, 2013 | 09:00 PM
TrickTurbo's Avatar
Truck Sponsor
You would have to run a flex hose.* wire reinforced hose. Something that won't collapse.
Or mod the air box lid.
Old Mar 14, 2013 | 09:05 PM
kbracing96's Avatar
A 4" 90* silicone, a hump couple and some 4" tube would probable get the job done
Old Mar 14, 2013 | 09:07 PM
You need to check the cfm's the panel filters flow...much less than a round open element .
Old Mar 15, 2013 | 02:03 AM
Ferocity02's Avatar
Also interested in doing this but wasn't sure how much of a restriction it would be.
Old Mar 15, 2013 | 04:15 AM
TURBHOE's Avatar
If you want to run a stock airbox, try and find a newer Dmax airbox. They flow a lot of air.
Old Mar 15, 2013 | 08:20 AM
nonnieselman's Avatar
here is how mine is setup.
This was all rough fitting it.
I used black RTV around the 4" goin into the airbox to seal it.
Old Mar 15, 2013 | 01:34 PM
turbo is really really quiet outside the truck. but towing you can hear it inside pretty good!
I took the filter out on the high boost passes and it comes alive.
ARC
57
Feb 21, 2022 10:54 AM
stealthperf
34
Feb 14, 2016 11:35 AM
The_W
Oct 28, 2015 09:00 PM
thunder550
Oct 8, 2015 04:53 PM
GMCtrk
Jul 17, 2015 06:39 PM
