W/M vs A/W intercoller
Old Mar 17, 2007 | 06:16 PM
hemidup's Avatar
Default W/M vs A/W intercoller
Could a good w/m injection setup, replace my a/w intercooler?
Old Mar 17, 2007 | 07:15 PM
Last Call's Avatar
TOTM: January 2007
Not sure why you would to replace your intercooler.. Is it not effecient? High IAT's?
Old Mar 19, 2007 | 07:40 PM
hemidup's Avatar
The intercooler that came with my kit is a Votech that was made for the 5.0 Fords. I now run 90 more cu in which should require about 25% more air. I feel that the intercooler is a restriction. I'm using a Snow Performance 150psi pump with dual 375 nozzels. I run a 40/60 w/m mix.
Old Mar 19, 2007 | 07:44 PM
nightrunner's Avatar
Mr. Obvious
if you have room a A/A IC should be more efficient, in conjunction with the W/M injection
Old Mar 20, 2007 | 01:38 AM
bad360rt's Avatar
11 Second Truck Club
How much boost are you losing through the intercooler? I say run both, that's what I'm doing. I spray methanol after the intercooler. Anything you can do to cool the charge is a good thing.
Old Mar 20, 2007 | 04:10 PM
MHSLOT12's Avatar
Default Coolers
Try A Cryo Or A Nitros Sprayer For The Front Of The Intercooler It Will Cool Your Intake Air
Old Mar 20, 2007 | 10:17 PM
hemidup's Avatar
Thanks, but it's an air/water intercooler with a Setrab aftercooler. I'm just trying to figure how much restriction the Vortech intercooler is actually producing. If restricted, I'm also concerned about the stacked compressed air temp between the outlet of the blower and the intercoooler.
Old Mar 21, 2007 | 12:32 AM
PappyDan's Avatar
Tribe Shaman
what is the size on your in and out openings on the intercooler 2.0 / 2.5 / 3.0 inch?
and what size is the core? H. W. L.
Old Mar 21, 2007 | 09:08 AM
hemidup's Avatar
PappyDan, Openings on the intercooler are both 2.75" and the core is 4.5"X4.5"X9".
Old Mar 22, 2007 | 09:33 PM
hemidup's Avatar
Pappy Dan, I take it your on to something about the core size and flow?
javier4.8
Oct 17, 2014 07:31 PM
charcold-bowtie
Jan 5, 2013 07:26 PM
Phantom
Oct 14, 2011 02:38 PM
smokeshow
Dec 19, 2010 10:32 PM
hemidup
Sep 22, 2007 04:25 PM
