Aftercooler times vs non cooler times.
Old Sep 21, 2007 | 01:46 PM
hemidup's Avatar
Default Aftercooler times vs non cooler times.
I posted up a few months ago and asked if anyone thought if my Vortech a/w aftercooler was a restriction. Being a Dodge, I didn't get much of a response. lol So I thought, what the heck. I pulled it off and took it to the track. My last years best time was a 12.65 @ 105.22. DA was 2200' in 84* weather. After pulling the aftercooler off, I gained about a lb of boost and ran the truck this year in 96* weather in 2800' air. Both year's I also used a Snow Performance w/m kit. My best run this year was a 12.30 @ 107.86. The truck weighs 134 lbs less this year compaired to last year. I picked up 2.64 mph and dropped .355 in et. As far as IAT's? They were a bit on the warm (hot) side. I'm going to be putting on some sort of cooler this winter. I just haven't decided whether I'm going with an a/a or a w/a.
Old Sep 21, 2007 | 01:57 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Interesting results but I DK if there's enough data to draw a conclusion. Perhaps if you repeatedly ran .35 seconds faster. Did you turn up the meth/water mix?
Old Sep 21, 2007 | 03:08 PM
hemidup's Avatar
I have three 12.40-42 @ 107 runs to back that up. The 12.40 runs were the following day in real thick air. I have my water meth set to come on at 6psi and ramp it up from there.
Old Sep 21, 2007 | 04:21 PM
hemidup's Avatar
If you look at my sig, you'll see the time and mph difference's in an 1/8 mi run in decent air compaired to a 1/4 mi run in bad air. Cold air should be here in MN in the next few weeks. Last year with the aftercooler, my best 1/8 was an 8 flat @ 85mph.
Old Sep 21, 2007 | 07:25 PM
IMD's Avatar
IMD
Banned
ok so your test data really means nothing because all of the variables are completely different. thanks though.
Old Sep 21, 2007 | 08:48 PM
MikeGyver's Avatar
How many miles on the truck? Maybe it's fully broken-in now?
Old Sep 21, 2007 | 11:21 PM
YenkoST's Avatar
They say for every 80-100 pounds is about a tenth off the quarter and you gained a psi so for a more comparable situation, the weight and psi needs to be the same IMO. Either way...nice times!!
Old Sep 22, 2007 | 04:25 PM
hemidup's Avatar
I have over 2,000 street miles and 200 passes on the new motor, plus 10 transmissions. lol
ferrellrooster
Mar 6, 2025 03:22 PM
outlawz2004
Sep 19, 2015 08:12 PM
GRRR65GTO
Aug 17, 2015 11:33 PM
kkirwan71
13
Aug 14, 2015 08:53 PM
ferrellrooster
Jul 17, 2015 07:07 AM
