Two stages of A2W water intercoolering
Old Feb 28, 2016 | 04:49 PM
  #21
53bowtie's Avatar
I assume you have meth? If not, why not add it to cool down your intake charge?
Old Feb 28, 2016 | 04:56 PM
  #22
03sierraslt's Avatar
If you have a properly sized intercooler this all becomes a mute point. I disagree, based on what you saying your intercooler isn't working very well. Go bigger, don't over complicate it. FYI adding a second hx to mine took my IAT from a 80-90 deg rise in the 1/4 to a 22 deg rise. That's a notable change.
Old Feb 28, 2016 | 08:35 PM
  #23
foxnutz's Avatar
I logged a full quarter mile this afternoon at 15 lbs of boost (I have yet to pulley back down from the winter). With methanol my IAT increased from 76 to 82 degrees during the run (with methanol). At 15 lbs of boost I should be adding 188 degrees to ambient temp, so my current set up is better than I thought (need to verify that my sensor is not getting soaked in water meth). Next weekend I am going to log with and without methanol and see the difference.
Old Feb 29, 2016 | 12:40 AM
  #24
Blown06's Avatar
8 Second Truck Club
Your sensor is probably getting hit with the meth giving a false reading. Regardless, I think you'll be doing more harm than good. It's your **** though, do it, post the results.
Old Feb 29, 2016 | 12:42 AM
  #25
Blown06's Avatar
8 Second Truck Club
Originally Posted by kbracing96
With a centrifugal supercharger, I don't know why you would be a/w intercooling anyway, unless its a mostly track setup and you want to add ice to the water to rapid cool it between rounds and what not. But a/a have shown over and over to me more efficient on the 90% street application. Just my 2c
Who am I to disagree with kbracing, but (and this is hearsay) I think people have had better results with A2W set ups with tap water on the street than with A2A. I can see where this would be true unless your doing like 24 back to back 200 mph pulls on the highway..........in which case it wouldn't matter anyway cause you'd either be dead or in jail. lol
Old Feb 29, 2016 | 04:30 AM
  #26
George C....'s Avatar
Formerly ScreamingL
A2w in a street vehicle is fine for a stock pulley once past that hello high IATs, in turbo setup its a solid setup.
A2w with ice chest works for 1 pass at a time for drag vehicles
For the OP to worry about 140* iats, theres other things to worry about instead
Old Feb 29, 2016 | 09:02 AM
  #27
I say OP is overcomplicating things. A single more efficient intercooler and heat exchanger would be better than trying to add a second cooler to aid an inefficient primary cooler.
Old Mar 10, 2016 | 11:25 AM
  #28
madmann26's Avatar
According to Atomic, my Whipple HE is doing a fine job.
I'm logging IAT x RPM x Cyl Airmass.
While cruising, my IATs are about 20 above ambient, on average. If I lean into it, they'll get to 110-120.
AUTOT3K
Jan 30, 2016 11:53 AM
sguiffre13
Jan 10, 2016 01:02 AM
BlueTexan24
Jan 6, 2016 10:39 PM
tim wellington
Jan 6, 2016 11:42 AM
mdwatts11
Dec 31, 2015 07:19 PM
