air filter size
Old Jan 5, 2016 | 03:36 PM
tim wellington's Avatar
Default air filter size
does any one know if there is big gain going from 6 in long cone filter to 10 long air filter both suck from the end .turbo set up
Old Jan 5, 2016 | 04:22 PM
Atomic's Avatar
I have a gauge for that
Worthwhile IMO
Old Jan 5, 2016 | 05:19 PM
George C....'s Avatar
Formerly ScreamingL
At track run open turbo youll gain alot more
Old Jan 5, 2016 | 06:01 PM
Default open air
tried that i.at rose up quess hot from radiator was getting suck in that when I switch to elbow to throw it behind headlight(remove light) at track
Old Jan 6, 2016 | 12:42 AM
TrickTurbo's Avatar
Truck Sponsor
Tim at the track loose the air filter. But keep the elbow.
You can even install a short section of 4" tubing to pull air from where your filter is now.
way back we had a customer take 4" flex tubing and route from the turbo to where the headlight was. Worked well. No hot air into the turbo.
Old Jan 6, 2016 | 11:14 AM
kbracing96's Avatar
This is what I did for mine for track use. I think it made a big difference.
But for DD, I'd find the biggest fitter you can fit and put it in the corner behind the headlight.
Old Jan 6, 2016 | 11:42 AM
TrickTurbo's Avatar
Truck Sponsor
Yep that might work.
NipRing
Apr 24, 2017 02:30 PM
Rise of the Phoenix
Jan 20, 2016 01:01 PM
Funkster
Jan 16, 2016 10:17 PM
JustAGoat
Jan 11, 2016 11:44 PM
ullose272
Jan 6, 2016 06:43 AM
