Two stages of A2W water intercoolering
#22
If you have a properly sized intercooler this all becomes a mute point. I disagree, based on what you saying your intercooler isn't working very well. Go bigger, don't over complicate it. FYI adding a second hx to mine took my IAT from a 80-90 deg rise in the 1/4 to a 22 deg rise. That's a notable change.
#23
I logged a full quarter mile this afternoon at 15 lbs of boost (I have yet to pulley back down from the winter). With methanol my IAT increased from 76 to 82 degrees during the run (with methanol). At 15 lbs of boost I should be adding 188 degrees to ambient temp, so my current set up is better than I thought (need to verify that my sensor is not getting soaked in water meth). Next weekend I am going to log with and without methanol and see the difference.
#25
With a centrifugal supercharger, I don't know why you would be a/w intercooling anyway, unless its a mostly track setup and you want to add ice to the water to rapid cool it between rounds and what not. But a/a have shown over and over to me more efficient on the 90% street application. Just my 2c
#26
A2w in a street vehicle is fine for a stock pulley once past that hello high IATs, in turbo setup its a solid setup.
A2w with ice chest works for 1 pass at a time for drag vehicles
For the OP to worry about 140* iats, theres other things to worry about instead
#28
According to Atomic, my Whipple HE is doing a fine job.
I'm logging IAT x RPM x Cyl Airmass.
While cruising, my IATs are about 20 above ambient, on average. If I lean into it, they'll get to 110-120.
AUTOT3K
Jan 30, 2016 11:53 AM
