Turbo Z71 project
I'm boosting a 5.3 Z71, Putting a .562 lift cam in it and only running 10 lbs max just for racing. It will probably be launched on the street with all for wheels but the drivetrain is getting a big upgrade. It's a daily driver that hauls trailers occasionally and requires a lot of reliability so it's probably only getting 7lbs daily driven and even less for towing. Any suggestions for valve springs? Remember reliability is a big issue.
I have yellow LS6 springs and I run about 10-10.5 lbs with my maggie with no problems. But I do have a little less lift, but I think duals with .562 is a little overkill. Just unneeded stress on the valve train IMO.
It happens to me last weekend. So I'm going a little overkill on the springs this time around. Bad things happen when heat hits the back of an intake valve.
https://www.performancetrucks.net/fo...=479680&page=4
2 solid choices in my opionion. Heavy spring pressures dont really affect to much in these modern motors. the cams are solid billet like and lobes dont flatten, most setups have a stout LS7 lifter, and the rockers stock have been 1000HP. pushrod length is more critical.
First choice is the Livernois Motorsports valve springs they handle i want to say .670 or .690 lift and are made by the same company that makes pro stock valve springs.
comp cams high end LS springs. they are pricy but they do what there made for.
PAC Racing .600" Lift Beehive Springs should get the job done without breaking the bank. I've read that a few people with higher mileage motors have had trouble with PRC dual springs when they didn't replace the valve seats at the same time. I have no experience with the PRC's myself but I do run 7lbs of boost & .581 lift with the PAC springs.
