turbo vacuum readings?
Old Jun 5, 2012 | 11:10 AM
jjc839's Avatar
Default turbo vacuum readings?
What are you guys seeing for vacuum at idle on your turbo engines? I have a MP70 on a 5.3 and it doesn't read less than zero on the boost/vacuum gauge at any time. This is my first turbo vehicle, I was under the impression they still made vacuum at low/idle rpm. The boost portion of the gauge works, just no vacuum. Thanks.
The gauge is connected to the PS port behind the throttle body.
Old Jun 5, 2012 | 11:12 AM
14psisupra's Avatar
Think mines around 14 vac at idle. 5.3 with m70 as well
Old Jun 5, 2012 | 11:15 AM
nonnieselman's Avatar
Sure the line hasnt collasped with vacuum?
I had that problem with some cheap clear tubing.. it would only read about 1psi vacuum.. but would read boost just fine
Old Jun 5, 2012 | 11:24 AM
kbracing96's Avatar
Are you talking about the port on the TB that the valve cover was connected to, or the port about 2/3 of the way back on the intake manifold?
Old Jun 5, 2012 | 11:27 AM
What are you calling the PS port?
Is it a larger 3/8" port, or the port on side of the intake manifold on about number 6 cyl runner?
Old Jun 5, 2012 | 11:31 AM
im a slow typer
Old Jun 5, 2012 | 11:43 AM
jjc839's Avatar
Ya the one the valve cover was connected to, it's still behind the throttle blade so should still work?
Old Jun 5, 2012 | 11:49 AM
kbracing96's Avatar
No, it isn't it turns in the TB and is in front of the tb blade. You need to connect your gauge to the port on the side of the intake manifold or the brake booster port.
Old Jun 5, 2012 | 11:54 AM
jjc839's Avatar
Good to know, thanks man
Oobray
Jun 13, 2022 03:38 AM
XL7
May 5, 2022 01:48 PM
mhorn0817
Jul 8, 2017 01:54 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Hmguyton
Jul 7, 2015 03:29 PM
