Turbo Size Help
Hi fellas,
I have a 2011 GMC Sierra 5.3 which has been turned to a forged 383 stroker. My current setup is in the sig, 94mm turbo which is not making good power. I am making 550 wheel horsepower at 15 psi and it is lifting the heads a bit. So, can't go any higher. I am not making full use of the turbo. I know the 94mm turbo was a mistake.
I am looking to size down. What size turbo would you go for on a 383 stroker?
I am looking to be around 900 - 1000 wheel horsepower
Thanks!
Thanks!
Thanks for the reply.
To be more realistic my goals are to be 800+ wheel horsepower.
As for the S480 there is a T4 and a T6 version. Which one would be more suitable for me? Also, what A/R would you go with?
You could realistically use either, but whatever matches your current hot side would be easiest. The T6 will be cheaper and have more top end, but the T4 will probably spool better.
Do you think that would've been good as well?
Also the A/R sizes available are:
-1.15
-1.32
-1.45
-1.58
I need your opinions as I do not want to make the same expensive mistake!
Thanks guys
