Turbo selection
Old Jan 24, 2007 | 04:35 PM
  #71
parish8's Avatar
single digit dreamer
Originally Posted by boostedsl2
boost level depends on the timing. you can run crazy boost with not timing, you just won't make any power.
most of my experience comes from four cylinder car, however there shouldn't be a difference as far as tuning goes. an engine is an engine. gas is gas.
there is a difference in ve usually between v8's and 4's, i will admit that, but it shouldn't change the tune.
you may start to ping at 11psi due to your tune. you might be able to run more psi with cooler intake temps, lower compresson and less timing. depends on what you want to do.
you could be right with these engines not being able to take that much boost, but concluding what an engine can and can't do based on just personal experience doesn't do it for me.
i know you make a ton of hp, i've seen the videos. in fact, your videos are one of the reasons i'm switched to trucks.
don't take this as an insult. i'll do a little more research.
sorry for the hi-jack
i hear you on the 4cyl motors running alot of boost on pump gas. i dont really know why or how they get away with it but it doesn't work on the ls1 motors. i have tried from 9deg up to 22deg of timing with a/f ratios from the upper 11's to high 10's. if i was to drop the timing all the way down to 9deg those boost limits i mentioned above will only go up a couple of psi and over all power would be less.
a higher ve would make a significant diference on max boost level. with a higher ve the motor will flow a lot more air at a given boost level. more air=more cyl pressure= detonation sooner.
if it were just me seeing low boost limits on pump gas i would agree with you that it could be the tune. on a whipple set up with no intercooler about 6.5psi is all i or anyone else is geting on pump gas. with an intercooled radix it seems like 8-9psi is a prety safe limit before knock sets in. it doesn't take much to get these motors knocking with no boost.
Old Jan 24, 2007 | 04:45 PM
  #72
thunder550's Avatar
High on diesel fumes
Originally Posted by thunder550
Specs on the recommended TO4B:
59mm wheel
Turbine
P trim
.96 A/r housing
Compressor
H trim
.70 A/r housing
Got another twin recommendation - TC62's, .68 a/r with MPS trim
Thoughts on either setup?
Old Jan 24, 2007 | 05:03 PM
  #73
boostedsl2's Avatar
i used to run 22psi with a t67 in my saturn daily on 93 octane. 8.5:1 though
if that hunk of crap can do it, i'm sure one of these trucks can.
if your going with twins, i would look at twin sc61's with stage 5 wheels.
that should be good for about 1200whp worth of air with decent spool.
Old Jan 24, 2007 | 05:24 PM
  #74
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The MPS line has alot lighter wheels which will help with spool. You got to remember though, its not just the cost of the turbo you are adding with twins, extra wastegate(250), extra piping, log header, flange(400ish), IMO a properly sized single will work best with your setup and easier to package. I really think the S-series may be a better option after talking to Jose today. The new Borg-Warner wheels are more aggresive, which make more power, are louder, more efficient, and make big power. They are on a t-6 flange, and Jose told me that the t-4 blanket will work it just wont cover it as well. He also said the pt-88 technology is 30+ year old turbo technology whereas the new borg-warner wheels and the s-series turbos are new cutting edge technology so Im sure you can imagine the difference in technology that is put into them. The S80 is going to be ~1600 with a coated exhaust housing.
Old Jan 25, 2007 | 07:55 AM
  #75
vanillagorilla's Avatar
I've seen good things from S series turbos and people on tech have big plans with them. It's worth looking into for sure.
Old Jan 25, 2007 | 09:03 AM
  #76
Wilde Racing's Avatar
How do I change this text
What about the 60-1s?
Old Jan 25, 2007 | 11:02 AM
  #77
What can you get 60-1's for these days?
Old Jan 25, 2007 | 11:43 AM
  #78
thunder550's Avatar
Jose at forcedinductions is recommending twin TC62's for what I'm wanting, .68a/r and mps trim. I'm thinking I want to make something using stock manifolds flipped to come up and forward, like the w2w single setup. As soon as I figure out this damn oil burning issue I'm going to be ready to jump into the turbo setup
Old Jan 25, 2007 | 02:48 PM
  #79
Pretty cheap I thought...
Old Jan 25, 2007 | 03:37 PM
  #80
boostedsl2's Avatar
i saw them for a little under $700 apiece. they are about the oldest turbo you can get these days though. you could get some gt journal bearings with similar flow characteristics, but much broader of a map keeping you in the efficency range a lot longer.
twin gt3782's would be a little bit smaller (about 10lb/min less). they about $800 apiece. much better compressor map.
