Turbo selection
Old Jan 25, 2007 | 07:50 PM
  #91
kbracing96's Avatar
Originally Posted by kbracing96
Those look NICE, but I bet they are not going to be cheap at all!
Edit: the small block ones are $995, I would only guess the ls1 mannis are going to be that or MORE.
Old Jan 25, 2007 | 07:56 PM
  #92
BlackGMC's Avatar
Resident Retard
If you want to get creative, you could take a set of stock manifolds and have someone cut and weld them in the position you want. I know someone or everyone will say you can't weld cast manifolds, but I have seen it done, it just takes a particular process most people don't want to do. You have to heat the manifolds up, basically cherry hot, weld some, let them cool and repeat several times. One of my fathers friends was (he passed away) was an excelent very experienced welder, and he took my took manifolds (previous vehicle) that broke into 2 pieces and was able to weld them back together. Do some searching at some welders around you, who knows you might be able to find someone like did.
  #93
Wilde Racing's Avatar
How do I change this text
Why is that intake on backwards?
Old Jan 25, 2007 | 08:13 PM
  #94
TG02Z71's Avatar
Maybe with the stock maniflds flipped you could have someone machine you up a spacer plate to push them out a little farther and at a slight angle to get more clearance where you want it for the wires and such, you'd need two exhaust gaskets but big deal.
It would be cheaper and easier than doing logs and still flow well, get them JetHot coated to keep heat in and be done with it. Just a thought.
Old Jan 25, 2007 | 11:12 PM
  #95
vanillagorilla's Avatar
Boat or airplane engine maybe?
Old Jan 25, 2007 | 11:42 PM
  #96
DrTurbo's Avatar
LS1TECH Sponsor
Somebody needs to tell forcedinductions that then, they told me that if I bought a pt76-gts that if I wanted to go to a pt-88 all they had to do is changed out the wheels.
Thunder you may also look into the S80, the more I look at it the more I think I want it. They have the new borg-warner wheels in them which make more power AND are louder
There is an S85 too I believe. The price is just a bit more then the pt76-gts and the pt-88.
I was listening to that conversation between you and Jose. I think you may have heard wrong. Jose was saying the 76GTS and PT88 share the same housing on the compressor side and T-4 flange, but not the same downpipe flange and he I believe said the PT88 is almost 1.5" longer from intake to downpipe flange.
As for the Borg Warners, yes, they are the shiznit for sure. Jose and Jason build some bad *** stuff.
Old Jan 25, 2007 | 11:44 PM
  #97
DrTurbo's Avatar
LS1TECH Sponsor
The MPS line has alot lighter wheels which will help with spool. You got to remember though, its not just the cost of the turbo you are adding with twins, extra wastegate(250), extra piping, log header, flange(400ish), IMO a properly sized single will work best with your setup and easier to package. I really think the S-series may be a better option after talking to Jose today. The new Borg-Warner wheels are more aggresive, which make more power, are louder, more efficient, and make big power. They are on a t-6 flange, and Jose told me that the t-4 blanket will work it just wont cover it as well. He also said the pt-88 technology is 30+ year old turbo technology whereas the new borg-warner wheels and the s-series turbos are new cutting edge technology so Im sure you can imagine the difference in technology that is put into them. The S80 is going to be ~1600 with a coated exhaust housing.
Jose speaks the truth, the 88 is based on the TV series from Detriot Diesels, I believe Jose said the 11.7, or 12.7 liter....crap I am not that savy with all those engines....lol. I know they have been around 25+ years.
Old Jan 25, 2007 | 11:46 PM
  #98
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by thunder550
The TC62's are about $800 each as well.
Your requirements are tough....lol. I think the TC62's would be a killer fit as well, and will be a nice mix of what you are wanting. It will support 1000+ hp and still spool nicely. Also the GT47RDBB Jose mentioned is a BAD piece. It makes nice power and spools better then the current big units, but it does have a nice price tag
Old Jan 26, 2007 | 12:06 AM
  #99
Stoichiometric's Avatar
A/W intercooler inside car?
Old Jan 26, 2007 | 12:44 AM
  #100
BlackGMC's Avatar
Resident Retard
This is why it is mounted backward (sorry to get off topic thunder), it is a rear mounted engine.
car details can be found bellow
http://www.schwartzperformance.com/alien.htm
