Turbo selection
Old Jan 25, 2007 | 03:45 PM
  #81
thunder550's Avatar
High on diesel fumes
The TC62's are about $800 each as well.
Old Jan 25, 2007 | 04:02 PM
  #82
kbracing96's Avatar
Originally Posted by thunder550
Jose at forcedinductions is recommending twin TC62's for what I'm wanting, .68a/r and mps trim. I'm thinking I want to make something using stock manifolds flipped to come up and forward, like the w2w single setup. As soon as I figure out this damn oil burning issue I'm going to be ready to jump into the turbo setup
The flipped stock manis, look pretty bad, and you have to relocate the coils, or build a heat shields and run longer plug wires around the end of the motor. I'll get you a pic of the motor I have with them flipped. I can build you a set of logs like parishes pretty easy, the down pipes are a little more tricky, but like I told you, you have to do a lot of re-wiring on the drivers side, especially with that rats nest you have
Old Jan 25, 2007 | 04:23 PM
  #83
thunder550's Avatar
Are the log manis any more or less efficient than the stock ones?
Old Jan 25, 2007 | 05:26 PM
  #84
boostedsl2's Avatar
who makes a coil relocation kit?
Old Jan 25, 2007 | 05:54 PM
  #85
parish8's Avatar
single digit dreamer
i would say a basic log like i have is not going to flow as well as the stock manifolds. i tried to use the stock manifolds and they didn't really lay out well for twins or even a single
Old Jan 25, 2007 | 05:57 PM
  #86
thunder550's Avatar
Hmm.....what was the problem? Coils and wiring like Kyle mentioned above?
Old Jan 25, 2007 | 06:00 PM
  #87
thunder550's Avatar
Kyle, I found your pic as well as a few others in a different thread.
It honestly doesn't look as bad as you guys are making it out to be...unless I'm missing something (well one thing I guess I see is that the Tahoe pic doesn't have a turbo hanging off the driver's side manifold....). Obviously I would have to clean up my wiring, but that might be a good thing. My driver's side looks pretty nasty right now.
Old Jan 25, 2007 | 07:18 PM
  #88
kbracing96's Avatar
Here is all the pics I just took. BTW, you can't point them down unless you ditch the AC (which I don't think you would do, ) and switch to car acc. cuz the SP pump hits on the DS.
Old Jan 25, 2007 | 07:27 PM
  #89
BlackGMC's Avatar
Resident Retard
I saw this when I was looking for some chasis componets for my car. Supposedly they are going to have some LSX Cast turbo manifolds ready soon. They have made a few proto types. They are designing them for a Gen 1 camaros, but they might fit a truck. You might want to give them a call, Just thought I would post a pic.
These are the ones for regular SBC, they look pretty nice to me. I would assume that the mount will be located in roughly the same spot as the ones below. Because there is no way they ones above would fit in Gen 1 camaro. The ones below are for a Gen 1 camaro.
Old Jan 25, 2007 | 07:45 PM
  #90
kbracing96's Avatar
Those look NICE, but I bet they are not going to be cheap at all!
