Turbo selection
Old Jan 26, 2007 | 01:00 AM
  #101
thunder550's Avatar
High on diesel fumes
Originally Posted by DrTurbo
Your requirements are tough....lol. I think the TC62's would be a killer fit as well, and will be a nice mix of what you are wanting. It will support 1000+ hp and still spool nicely. Also the GT47RDBB Jose mentioned is a BAD piece. It makes nice power and spools better then the current big units, but it does have a nice price tag
Yeah that GT47 sounded nice, but if twins would get me closest to what I want with the least amount of compromise then that's how I'm gonna go Plus, if I can find a relatively cheap way to do the hot piping, I think I'll save some $$ in the long run too.
Old Jan 26, 2007 | 06:29 AM
  #102
parish8's Avatar
single digit dreamer
Originally Posted by thunder550
Hmm.....what was the problem? Coils and wiring like Kyle mentioned above?
forward and down hit the frame and accesories. forward and up put the outlets on the turbos to high and at a bad angle for twins. for a single you can see they made it work but to me it looks very busy. rerouting the plug wires, heat shields all over. tubing everywhere.
i do think it would be the best performing and most durable way to do it. just not the easiest or best looking. building a log manifold took me about one evening each and allowed me to put the turbos right where i wanted.
Old Jan 26, 2007 | 09:42 AM
  #103
FMOS Racing's Avatar
Originally Posted by parish8
i hear you on the 4cyl motors running alot of boost on pump gas. i dont really know why or how they get away with it but it doesn't work on the ls1 motors.
Because most DOHC engines with cross-flow valve arrangements have a far more efficient combustion chamber than in-line valve pushrod motors. That increase in efficiency helps control the consistency of the flame front.
Old Jan 26, 2007 | 09:45 AM
  #104
Originally Posted by BlackGMC
This is why it is mounted backward (sorry to get off topic thunder), it is a rear mounted engine.
car details can be found bellow
http://www.schwartzperformance.com/alien.htm
Oooooooooooooooooooooooo... I like!
Old Jan 26, 2007 | 07:35 PM
  #105
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Your are going to have a nice setup either way, me personally I would go with an S80 due to easier packaging and less money, along with not having to build a second header.
Old Jan 26, 2007 | 07:36 PM
  #106
1slow01Z71's Avatar
I was listening to that conversation between you and Jose. I think you may have heard wrong. Jose was saying the 76GTS and PT88 share the same housing on the compressor side and T-4 flange, but not the same downpipe flange and he I believe said the PT88 is almost 1.5" longer from intake to downpipe flange.
As for the Borg Warners, yes, they are the shiznit for sure. Jose and Jason build some bad *** stuff.
Damn, guess I need to pay more attention next time, guess the loud noise of the drilling rigs and and other construction equipment messed with my hearing.
Old Jan 31, 2007 | 01:58 PM
  #107
thunder550's Avatar
Will I think I might re-evaluate again. After driving my truck around for a few days and paying closer attention to where I'd like to have more power (boost), I think the pt-76gts might be the way to go. I just want the boost to be there at any given moment. I think that might be a good start, then I can go up from there if I feel the need to. Or I can just spray on it to get me where I want to be.
Old Jan 31, 2007 | 09:31 PM
  #108
1slow01Z71's Avatar
I think you will like it, or the S80, either should get the job done with the S80 having quite a bit more power potential. Call Jose again
Old Feb 1, 2007 | 01:15 PM
  #109
thunder550's Avatar
I'll have to call and ask about the S80 too.
lxcoupe
Sep 6, 2017 08:24 AM
EmmerichLSx
Sep 14, 2015 09:47 AM
chvy=power
Sep 8, 2015 11:06 AM
slowswb
Sep 5, 2015 02:27 PM
stock48
11
Aug 18, 2015 05:55 AM
