Turbo or S/C for 6.2L? Questions...
Old Aug 19, 2010 | 07:15 PM
  #101
fasterthenyou's Avatar
Ok well either way y'all it don't matter... I'm going to put the filters in a good location...
What's the best location for the freshest air? I can always put on pre filters for rain/ snow... But I want something that will be fairly protected from the elements...
Maybe put 90* down cause heat rises behind the bumper area...?
But back to the oil adapter/ pressure port. Lingenfelter makes an adapter that goes where the oil temp sensor is I think.... Anyone use one? Where is the oil temp sensor?
Or a sandwich plate from Glowshift.com
Old Aug 19, 2010 | 09:30 PM
  #102
Quik's Avatar
5 year bitches!
oil temp is on the vettes and the adapter i was talking about. trucks and fbodys dont have oil temp but vettes do, reason being why certain vehicles got the left over adapters
Old Aug 19, 2010 | 09:41 PM
  #103
BlackGMC's Avatar
Resident Retard
here you go
https://www.performancetrucks.net/fo...&highlight=oil
also if you search these keywords (ls1 oil adapter)on ebay you will find this for $14.99
Old Aug 19, 2010 | 11:29 PM
  #104
^^^^^ will that part keep me from having to tap anything correct? It replaces the piece you'd otherwise have to drill/tap... And that will be the oil supply that I will T off and run one line to each turbo...
Old Aug 20, 2010 | 12:47 AM
  #105
smokeshow's Avatar
Mod with training wheels
You will still need to tap the pan. This just makes the oil feed side look cleaner.
Old Aug 20, 2010 | 07:41 AM
  #106
Quik's Avatar
5 year bitches!
youll have to put a hole or 2 in the pan for oil drains but the one fitting is what you need.
Old Aug 20, 2010 | 09:42 AM
  #107
Yeah... I just meant the feed side. I know I'll have to tap 2 drain holes in the front of the pan... But does that piece replace the other cast looking one..?
Ok so to conclude the oil system.
-4AN feed Td off into 2, one to each turbo.
-10 AN seperste return lines into front of oil pan.
Where should I get all this hose, fittings, flanges?
Old Aug 20, 2010 | 10:12 AM
  #108
charcold-bowtie's Avatar
summit jegs anywhere. Just look in the AN stuff and get pushlock barbs
Old Aug 20, 2010 | 07:25 PM
  #109
Are most of y'all running blow thru MAF? Or MAP? I'm used to fords where you usually run MAF...
Old Aug 20, 2010 | 08:10 PM
  #110
stock uses both, i would drop the maf, at 1k horses it would be plenty maxed out
