Turbo or S/C for 6.2L? Questions...
#101
Ok well either way y'all it don't matter... I'm going to put the filters in a good location...
What's the best location for the freshest air? I can always put on pre filters for rain/ snow... But I want something that will be fairly protected from the elements...
Maybe put 90* down cause heat rises behind the bumper area...?
But back to the oil adapter/ pressure port. Lingenfelter makes an adapter that goes where the oil temp sensor is I think.... Anyone use one? Where is the oil temp sensor?
Or a sandwich plate from Glowshift.com
#102
oil temp is on the vettes and the adapter i was talking about. trucks and fbodys dont have oil temp but vettes do, reason being why certain vehicles got the left over adapters
#103
here you go
https://www.performancetrucks.net/fo...&highlight=oil
also if you search these keywords (ls1 oil adapter)on ebay you will find this for $14.99
#104
^^^^^ will that part keep me from having to tap anything correct? It replaces the piece you'd otherwise have to drill/tap... And that will be the oil supply that I will T off and run one line to each turbo...
#106
youll have to put a hole or 2 in the pan for oil drains but the one fitting is what you need.
#107
Yeah... I just meant the feed side. I know I'll have to tap 2 drain holes in the front of the pan... But does that piece replace the other cast looking one..?
Ok so to conclude the oil system.
-4AN feed Td off into 2, one to each turbo.
-10 AN seperste return lines into front of oil pan.
Where should I get all this hose, fittings, flanges?
