Turbo return question
Old Nov 7, 2013 | 09:15 PM
squirellhall's Avatar
Default Turbo return question
I have my turbo mounted and i am setting up the oil feed and return ....since my turbo is above the oil cap can I return it back into the cap ? Like the sts kit? Thanks in advance
Old Nov 7, 2013 | 09:43 PM
kelsey_canard's Avatar
Are you running a scavenge pump? If so, yes.
Old Nov 7, 2013 | 09:54 PM
No but it's above the cap so won't it gravity feed ? Just like back into the pan?
Old Nov 7, 2013 | 10:25 PM
TrickTurbo's Avatar
Truck Sponsor
Your drain is above the cap? Turbo must be pretty hi?
Old Nov 7, 2013 | 10:35 PM
Atomic's Avatar
I have a gauge for that
I dont really recommend it, it will drain much better to the pan or front cover.
Old Nov 7, 2013 | 11:03 PM
Ferocity02's Avatar
What is the vertical distance from the oil outlet port on the turbo to the oil cap?
Old Nov 8, 2013 | 07:51 AM
darnie's Avatar
Did you pull the tube off and just mount the cap to the valve cover? Just wondering because i habe dp remove mine due to it setting on the turbo blanket and it is alot lower than the feed but not my drain? I have mine going into the timing cover tho...
Old Nov 14, 2013 | 12:40 PM
id say its about 8" above the oil cap i drilled and tapped the cap and have it all set up should be running this weekdn ..... and yes i pulled the tube off becuase it had a crack which is what gave me the idea because how low it set ! its a very slight angle down from the turbo to the cap i think it should be ok
Old Nov 15, 2013 | 12:16 AM
Alpinestar's Avatar
Do you have a hood on your truck? Your turbo sits up a lot higher than mine
Old Nov 15, 2013 | 12:40 AM
silver-mod-o's Avatar
Hunt&Fisherator
Post a pic of this thing...
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 1, 2015 07:45 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mzay
Jul 6, 2015 11:03 PM
