turbo kit
I'm sitting at $3,847.21 with mine so far, and I still need fuel pump, injectors, boost controller, spark plugs, tuning, and exhaust wrap. Then the small stuff like vacuum line and such. I'm buying everything new, but shopping heavily for the best deals.
That doesn't take into consideration the cost of a rebuilt trans or the swap to a 4l80e, or replacing the G80 in your rear end with a decent unit.
For your absolute most basic kit, possibly around $3,000, it only goes up from there though.
I'd try to get a KB or Trick 70mm non-intercooled turbo kit at least like stated.
You can find good deals on USED rear mount STS turbo kits with the 67mm turbo. I have seen them go for $1700-$2000 totally complete, but you will still need a tune. That price is prob going to be the Non intercooled version as well. You could run that setup with 5-7# on a conservative tune until you can save up for a built trans, intercooler and possibly meth because sooner or later the trans is going to give and you will also want more out of it in due time..
