turbo help 6.0 lq4
Old Jun 19, 2014 | 01:34 PM
kisscj94's Avatar
Registered User
Default turbo help 6.0 lq4
Whats up guys just picked up a trans am with a lq4 swap has a GT45R turbo has a couple codes such a the tps and a couple 02 sensors idle was going up and down so I disconnected the iac sensor but even before that I had a running problem turbo would kick sometimes and other times it would spool and seem to choke out and pop before I let off going from first it seems like it boosts fine but the gears after thay it seems like it wants to choke out. Lq4 has 317 heads ls6 intake mani 70 lbs injectors with an upgraded fuel pump. Im thinking it might be a fuel problem but im not so sure new to gm motors any help is appreciated thank you!
Old Jun 19, 2014 | 01:37 PM
timmay208's Avatar
going to need to know what codes its throwing
whats Air/fuel when it cuts out
what spark plugs/gap
who did the tuning? have you contacted them?
Old Jun 19, 2014 | 01:52 PM
kisscj94's Avatar
Registered User
Codes are p0151 p031 banks 1 and 2 p0122 cutting out at 17.0 havent checked plugs yet and I have no idea who did the tuning
Old Jun 19, 2014 | 02:05 PM
timmay208's Avatar
17.0 is very very lean, if you are getting that AFR under boost you should stop going WOT asap. either you have low fuel pressure or something going on in the fuel system
Old Jun 19, 2014 | 02:11 PM
kisscj94's Avatar
Registered User
How can I adjust the fuel pressure?
Old Jun 19, 2014 | 02:24 PM
timmay208's Avatar
depends on if it has an adjustable regualtor, without knowing everything about the car its going to be hard
Old Jun 19, 2014 | 02:30 PM
kisscj94's Avatar
Registered User
I didnt see any adjustable feature on the fpr
Old Jun 19, 2014 | 02:31 PM
kisscj94's Avatar
Registered User
So does this mean new fpr?
Old Jun 19, 2014 | 03:32 PM
mdwatts11's Avatar
What kind of regulator and do you have a fuel pressure gauge?
Old Jun 19, 2014 | 04:48 PM
GRRR65GTO's Avatar
See what the fuel pressure is and if its ok Id go find a good tuner and have him look at it. Because for all you know someone could have built it and tried to tune it themselves that has never tuned.
Yeah your pistons arent going to like 17 a/f for much longer
How much boost does it make?
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Cowboy17
Jul 9, 2015 08:22 PM
NuckenFuts
Jul 9, 2015 08:45 AM
davis28905
Jul 8, 2015 03:20 AM
