Flex Fuel Injector and Wiring Harness - Convert to standard high performance injector
Old Jan 17, 2010 | 05:17 PM
lwyckoff's Avatar
Registered User
Default Flex Fuel Injector and Wiring Harness - Convert to standard high performance injector
Hello All. I am mid-install on a magnacharger. I went to plug the wiring harness into the injectors, and they will not fit. After doing some searches of pictures on the net, I believe that because my vehicle is FLEX fuel, it has different injectors AND a different wiring harness than normal set-ups. As a result, I am unable to connect the high-performance injectors that installed as part of the magnacharger kit.
Does anyone know of a conversion kit from flex fuel wiring harness to standard injectors? I'm sure others have run into this issue plenty of times. Thank you for the help.
Old Jan 17, 2010 | 05:37 PM
truckmann's Avatar
I don't think the wiring harness is different, but the plugs to the flex fuel injectors are different. You should be able to get the standard non-flex fuel style plugs and replace the ones you have to work with the injectors that come with the maggie.
Old Jan 17, 2010 | 05:57 PM
lwyckoff's Avatar
Registered User
Default Do you know the pound rating of the injectors that come with Magnacharger
And how those compare to the pound rating of a stock flex fuel injector? I have found one person who claimed 38 pounds for a stock flex fuel injector, but don't know that to be accurate.
Old May 31, 2014 | 11:45 AM
Black05Crew's Avatar
Will swapping the connectors allow me to run standard injectors?
Old Jun 2, 2014 | 10:08 PM
Gadgetized's Avatar
Are you tuning this with a handheld programmer from Magnacharger that came with the kit? Or are you getting a professional tune? If you are getting a professional tune, just get injectors of adequate flow rating that plug in and tell your tuner what you have.
Old Jun 20, 2014 | 02:06 PM
supersub's Avatar
flex fueled vehicles use USCAR style injectors, those are what all current models are leading towards, a good direct bolt on injector is available using those connectors
Closer_2001
Jul 21, 2015 03:25 PM
lxcoupe
Jul 21, 2015 02:12 AM
Aboss
Jul 9, 2015 10:28 AM
jrplz
Jul 9, 2015 12:07 AM
blackdc3
Jul 7, 2015 07:52 PM
