Turbo gauges?
Old Apr 13, 2014 | 06:56 PM
  #31
Ferocity02's Avatar
Originally Posted by TURBHOE
The problem with using wideband to find a drop in fuel pressure is, how do you know if it's the tune or the fuel press. I kept adding fuel to mine cause it looked like it was getting lean do to rpm and boost pressure. When actually my pump wasn't keeping up. Once the guage went in I could see it was a pressure issue.
What I was trying to say is that I log fuel pressure while tuning to ensure the fuel system can keep up. Then in everyday driving if the pump starts to fail or something else happens that causes a reduction in fuel pressure, it will show lean on the wideband, which is the gauge I keep my eyes on most of the time in boost. If it shows lean then I'll start logging data and see that the fuel pressure is lower than normal.
I just don't like the clutter of a bunch of gauges, so I kept them to a minimum (wideband and boost)
Old Apr 13, 2014 | 08:59 PM
  #32
TURBHOE's Avatar
But you had to install a fuel pressure sensor to log fuel pressure.
Old Apr 13, 2014 | 09:13 PM
  #33
Chevy_King1500's Avatar
boost and fuel pressure on the pillar and my wideband is where the airbag key thing used to be
Old Apr 14, 2014 | 12:10 PM
  #34
Ferocity02's Avatar
Yes, I bought the sender by itself and wired it into the EGR sensor wires so it was a really clean install, so I don't have an extra gauge in the cab for fuel pressure. It's just personal preference, that's all.
Old Apr 14, 2014 | 12:47 PM
  #35
timmay208's Avatar
what pressure sending unit did you use, i was debating doing that same thing
Old Apr 14, 2014 | 02:12 PM
  #36
Ferocity02's Avatar
Autometer 2246. It was a little pricey but I think it's higher quality than some of the cheaper ones you can get. It's held up for 1.5 years now. It uses the same connector as the coolant temp sender.
Old Apr 18, 2014 | 04:10 PM
  #37
So.cal Wrk Sled's Avatar
Thumbs up
Originally Posted by LPCWS6
Does anyone have a Zeitronix ZT-2. Here's a link.
Zeitronix Zt-2 : SEMA Award Winning Wideband Engine Datalogging System
Also check out this Display for it. I think it does everything but scratch your *** for you.
Zeitronix DashDAQ XL : Touch Screen Display for the Zt-2 Wideband Engine Datalogging System and OBDII Compatible Vehicles
LPCWS6, Thanks for posting info, I just got off phone with these guys! I'm going to do zt2 with egt, boost, afr/wideband. 'Thank god', no freakin gauge POD!!
Old Apr 18, 2014 | 08:41 PM
  #38
LPCWS6's Avatar
Just make sure you post up a review on how it works out for you. I'm debating on getting the same setup myself.
GXPJAY
Feb 13, 2022 08:15 AM
thunder550
Oct 8, 2015 04:53 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Ls3silverado
Jul 31, 2015 04:22 PM
