turbo gaskets?
Old Apr 21, 2009 | 11:34 PM
Phantom's Avatar
11 Second Club
Default turbo gaskets?
what kind of gasket do you all use between the turbo and the manifold? copper? stainless steel? cometic?
Old Apr 21, 2009 | 11:44 PM
kbracing96's Avatar
I don't use any, just high temp copper rtv to seal any imperfections and help lubricate it when expanding and contracting with heat.. Same with the waste gate. If the surfaces are good and flat (I check them with a file) they seal REALLY well. Nothing to blow out that way...
I do use a gasket between the head and the manifold, but its the same stock one that came on the truck. Ben reused a few times. I only keep it cus it's aluminum to steel and will expand at different rates and need to move a little and the ss stock gasket helps it to move with out galling.
Old Apr 21, 2009 | 11:46 PM
Phantom's Avatar
11 Second Club
ok cool deal. i didn't remember seeing anything about this before but was browsing around and somethin caught my eye so i figured i'd ask
Old Apr 22, 2009 | 12:02 AM
thunder550's Avatar
High on diesel fumes
I use a copper gasket between the manifold and turbo. I don't like using goop, too much of a PITA to remove and reapply IMO.
Old Apr 22, 2009 | 12:03 AM
SpoolinChevy's Avatar
Mine came with a copper gasket also.
Old Apr 22, 2009 | 12:09 AM
mike06tork's Avatar
stainless steel here T4... works real good & gets the job done nice. IMO
Old Apr 22, 2009 | 06:55 AM
Coban's Avatar
Same.
Old Jul 4, 2009 | 12:23 PM
TURBHOE's Avatar
does anybody use anything on the v-band flange? at work we use metal tape on the v-bands on the bleed airline and what not on the t56 engine. seems to hold pretty good. and the hot compressed air.
Old Jul 4, 2009 | 01:01 PM
Wilde Racing's Avatar
How do I change this text
stamped steel t-6 here. I use goop for the waste gate....
Old Jul 4, 2009 | 03:18 PM
Rick_Vor's Avatar
Hi-Temp red RTV on the turbo-exh manifold surface and on the v-bands. Seems to work great.
Stock OEM metal exhaust gaskets between head and manifold.
Rick
5.3lSilverado
25
Aug 29, 2016 12:48 AM
chopperloco
Jul 10, 2016 10:45 PM
yellow2000S/R
Mar 12, 2016 04:33 AM
thunder550
Oct 8, 2015 04:53 PM
