tune affect boost?
Old Sep 24, 2011 | 12:10 AM
idahoblkss's Avatar
im going to have to disagree with some here... after i did my trans and cam swap i lost a crap ton of boost( from 11# down to like 3# ) but my tune was F'ed to say the lest like REAL bad couldnt even hit full rpms. so depending on how bad your tune is it could effect it. how old is your blower? could need a refresh maybe , i know they are known to be rebuilt allot.
Old Sep 24, 2011 | 07:20 AM
I can hit top rpm no problem there. It was refreshed last summer and put a new belt in it this summer.
Old Sep 24, 2011 | 11:11 AM
idahoblkss's Avatar
belt slip maybe?
Old Sep 24, 2011 | 12:59 PM
kbracing96's Avatar
Crank pinned?
Old Sep 25, 2011 | 11:13 AM
new belt and tight so i don't believe its that. No pinned crank, what does that do?
Old Sep 25, 2011 | 11:41 AM
kbracing96's Avatar
Pinned crank keeps you balancer from spinning on the crank since there is not a key in them. I would check that and see if your crank bolt is even still tight.
Old Sep 25, 2011 | 12:20 PM
1Bear's Avatar
Bottom line is how is your truck performing? Is running any different than when you were able to hit 8lbs? If not, you may have a simpler issue. Mine fell off to where it was only showing 4 to 5lbs and I was like what the hell is going on and started down the same path of checking everything and what I found was the rubber boot on the end of the line for my Autometer gauge had deteriorated where it attached to my vacuum port and was leaking boost and just getting an incorrect reading.
And yes, when trying to push that amount of boost, I would definitely pin the balancer.
Old Oct 2, 2011 | 10:52 PM
Ever since I got the leaks fixed, it's runnin like a dog off the line. I floor it and it's holding back, I have to let off and ease into it. For your boost leak, did it show on a pressure leak sow test? Mine holds boost from the supercharger right through.
Old Oct 2, 2011 | 11:14 PM
02'Z71ONDUBZ''s Avatar
Why dont you just log your boost through HP Tuners? Have you pressure tested your your system for leaks? Sounds like it falls on its face when you go WOT which makes me think you have a tune issue. However if your spinning the balancer on the crank I could see this happening if your tune is set up to fuel for high boost but your only making two or three lbs. Do you have access to a wideband?
Old Oct 9, 2011 | 10:10 PM
I tried quite a while ago to log boost through hp and all I got was errors and gave up. Should give it a go again. I just re-tested the system and it has a very slow leak, it takes just under a min to bleed off 10 lbs. Yeah it falls on it's face at WOT. I could mark the pulley to see if it's moving. I am running a wideband. I was always in the 11's before the leaks were fixed and now i'm in the low 10's possibly 9's as it only goes to 10.0.
