tune affect boost?
Will a bad or lack of a tune affect getting decent boost levels? I have all my leaks sealed and can only hit 3lbs with a 10lb capable pulley.
No, or not in any instance I can think of.
K, back to the drawing board.
what are your cam specs? what is your comp with those heads?
The 265 cam is the 212/218 rite??
Those ported 317's on top of that 5.3 def dont help with boost #'s unless they were milled ALOT lol.. |
been told that lack of timing can cause boost to be lower. don't know why or if its true, but i was told by someone in the fi world for a while. even if its true it wouldn't cause it to be that much lower .
I've been told that Powerdyne blowers are garbage.
Cam specs:
54-412-11 - XFI RPM Hydraulic Roller Camshafts The 317's have been milled but minimal to clean them. I have seen upwards of 10 in the past, then I started having a couple different leak down problems. Which I hope I have fixed. So far It holds pressure and has a very slow leak. I can't get past 3 lbs even to redline. I have seen 8 pretty constant before the last leak. |
You need to elaborate on your problems...
Originally Posted by 02'Z71ONDUBZ'
(Post 4779069)
