tune affect boost?
Old Sep 21, 2011 | 06:55 PM
Default tune affect boost?
Will a bad or lack of a tune affect getting decent boost levels? I have all my leaks sealed and can only hit 3lbs with a 10lb capable pulley.
Old Sep 21, 2011 | 08:18 PM
charcold-bowtie's Avatar
No, or not in any instance I can think of.
Old Sep 22, 2011 | 07:58 AM
K, back to the drawing board.
Old Sep 22, 2011 | 08:14 AM
sharpshooter's Avatar
what are your cam specs? what is your comp with those heads?
Old Sep 22, 2011 | 10:00 AM
andrew383's Avatar
traveling mod
The 265 cam is the 212/218 rite??
Those ported 317's on top of that 5.3 def dont help with boost #'s unless they were milled ALOT lol..
Old Sep 22, 2011 | 10:26 AM
black4.8's Avatar
been told that lack of timing can cause boost to be lower. don't know why or if its true, but i was told by someone in the fi world for a while. even if its true it wouldn't cause it to be that much lower .
Old Sep 22, 2011 | 04:20 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I've been told that Powerdyne blowers are garbage.
Old Sep 23, 2011 | 04:35 PM
Cam specs:
54-412-11 - XFI RPM Hydraulic Roller Camshafts
The 317's have been milled but minimal to clean them. I have seen upwards of 10 in the past, then I started having a couple different leak down problems. Which I hope I have fixed. So far It holds pressure and has a very slow leak. I can't get past 3 lbs even to redline. I have seen 8 pretty constant before the last leak.
Old Sep 23, 2011 | 07:50 PM
02'Z71ONDUBZ''s Avatar
You need to elaborate on your problems...
Old Sep 23, 2011 | 10:54 PM
My problem is i'm not hitting full boost at 10 lbs. And I don't know why. All I can get right now is 3 lbs. I know for a fact I have hit 8 lbs. I'm not leaking from the plumbing from the blower through the intercooler or engine. I have a new belt and is tight.
