Trick turbo installation and review
Old Mar 23, 2016 | 01:58 PM
  #251
crashmymax's Avatar
Originally Posted by YAMAHAGUY
I've got a cooler I just pulled off mine and replaced it with the 40k tans cooler. It's practically brand new, just flush out the ATF and you can just PayPal me the cost to ship it to you.
Ive got my stock trans cooler still after putting on the tru cool. Will that work for the oil cooler?
Also thanks for the generous offer.
Old Mar 23, 2016 | 02:36 PM
  #252
YAMAHAGUY's Avatar
Originally Posted by crashmymax
Ive got my stock
I don't see why not. Just flush the ATF out and you'll have to get the zip tie things that go through the radiator or mount it some other way. It looks new and was my trans cooler until I replaced it. Maybe someone else may think otherwise. Here's a pic and it has 3/8" inlet and outlet.
I've gotten a lot of help from people on here and I'd like to pay it forward. And it sounds like you need any financial break you can get.
Old Mar 23, 2016 | 07:35 PM
  #253
TrickTurbo's Avatar
Truck Sponsor
Cooler is a cooler. Won't matter. Trans oil or engine oil your fine.
Flush / drain what trans fluid you can out and call it good.
Old Mar 23, 2016 | 08:17 PM
  #254
crashmymax's Avatar
That would work great. Ill send you a pm.
Old Mar 24, 2016 | 01:39 PM
  #255
crashmymax's Avatar
about ready to put the engine back into the truck but not sure what to do with the drive plate. When I pulled it I put #1 cylinder at TDC and marked the top of the plate so it would go on the same way. Does it matter now that its going on a different engine? Is there a certain way it should be installed?
Old Mar 24, 2016 | 01:43 PM
  #256
YAMAHAGUY's Avatar
Sent you a PM
Old Mar 24, 2016 | 05:09 PM
  #257
crashmymax's Avatar
Just got the engine back in. Hopefully Ill have time this weekend to get everything hooked back up. Then I need to get some opinions on the best and most reputable mail order tuners.
Old Mar 24, 2016 | 09:34 PM
  #258
dantheman1540's Avatar
I have an auto cal from BBP my truck isnt anything fancy but they are always quick and I've had no problems with them. When I asked about boosting my truck he said he had done many of them.
Old Mar 24, 2016 | 11:32 PM
  #259
FetzerValve's Avatar
+1 on BBP tune. I will be using them when I get my turbo on.
Old Mar 25, 2016 | 10:01 AM
  #260
crashmymax's Avatar
forgot to post this when I pulled the engine. I kept track of just about everything but found this under the truck after removing the engine. Not sure if it goes on the bellhousing or engine. Anyone recognize it?
