Trick turbo installation and review
#151
I believe mine is 28 inch and its not impacting max power because I have a cut out at the bottom of the down pipe.
#152
Tuner started on my truck again this afternoon. Have not heard from him so im a little bit worried. Im already in it for $583 and dont want to pay anymore. Hopefully ill be getting a call in the morning to pick it up. Can't wait!!
#154
Just talked with tuner. Poor guy worked till midnight on the truck. Was having an issue with the zr1 map sensor and traction control. After getting everything figured out he saw 420 hp at 10.7psi
. After my cam install and original tune the truck always had idling issues. Every once in a while it would stall out on me when coming to a stop. He is going to work on fixing that today. Said when he is done the truck will idle and drive just like it did from the factory. Until boost of course. So I will get the truck tomorrow or monday. The anticipation is unreal! Then i can give a review of the trick stage2 kit performance end of things.
Also should add the tuner was impressed with the quality of the kit. He had few suggestions about 02 sensor placement but overall nice kit. Far above a on3 kit.
. After my cam install and original tune the truck always had idling issues. Every once in a while it would stall out on me when coming to a stop. He is going to work on fixing that today. Said when he is done the truck will idle and drive just like it did from the factory. Until boost of course. So I will get the truck tomorrow or monday. The anticipation is unreal! Then i can give a review of the trick stage2 kit performance end of things.Also should add the tuner was impressed with the quality of the kit. He had few suggestions about 02 sensor placement but overall nice kit. Far above a on3 kit.
#155
