Trick turbo installation and review
Old Feb 24, 2016 | 01:32 PM
  #151
Choda's Avatar
Originally Posted by crashmymax
Minus the nice stainless and perfect welds . Do you have the 30" magnaflow? Think that restriction is making any difference on how your ttruck runs?
mine is stainless and "perfect" welds l
I believe mine is 28 inch and its not impacting max power because I have a cut out at the bottom of the down pipe.
Old Feb 26, 2016 | 08:44 PM
  #152
crashmymax's Avatar
Tuner started on my truck again this afternoon. Have not heard from him so im a little bit worried. Im already in it for $583 and dont want to pay anymore. Hopefully ill be getting a call in the morning to pick it up. Can't wait!!
Old Feb 27, 2016 | 10:53 AM
  #153
crashmymax's Avatar
This tuning stuff is driving me crazy! I should have just done a mail tune from a vender. Might not get max performance but atleast i would have my truck and safe tune.
Old Feb 27, 2016 | 11:22 AM
  #154
crashmymax's Avatar
Just talked with tuner. Poor guy worked till midnight on the truck. Was having an issue with the zr1 map sensor and traction control. After getting everything figured out he saw 420 hp at 10.7psi . After my cam install and original tune the truck always had idling issues. Every once in a while it would stall out on me when coming to a stop. He is going to work on fixing that today. Said when he is done the truck will idle and drive just like it did from the factory. Until boost of course. So I will get the truck tomorrow or monday. The anticipation is unreal! Then i can give a review of the trick stage2 kit performance end of things.
Also should add the tuner was impressed with the quality of the kit. He had few suggestions about 02 sensor placement but overall nice kit. Far above a on3 kit.
Old Feb 27, 2016 | 01:22 PM
  #155
gammey4's Avatar
420 at 10psi seems really low with it already having a cam installed.
Old Feb 27, 2016 | 02:30 PM
  #156
crashmymax's Avatar
It does seem low thought I'd be closer to 450. Unfortunately its not a turbo cam so not sure it does me any good or not.
Old Feb 27, 2016 | 05:33 PM
  #157
Choda's Avatar
i agree 420 w a cam is a little low. get it running first then maybe think about a vendor taking a look at the tune.
Old Feb 27, 2016 | 11:08 PM
  #158
abey15's Avatar
Seems a little low. Mine made like 414 a coupe days ago on about 7 psi on a stock 04 4.8.
Old Feb 29, 2016 | 03:52 PM
  #159
crashmymax's Avatar
Just talked with the tuner my truck has a dead cylinder. Not sure where to go from here.
Old Feb 29, 2016 | 03:55 PM
  #160
FFDP's Avatar
Dead as in what?
A hole in a piston or misfire from something on a spark system or a broken valve spring??
