trick turbo ?
Old Sep 6, 2011 | 11:14 PM
jgb454ss's Avatar
Default trick turbo ?
has anybody used the trick performance tubo setup. I am having trouble figuring out the placement of the intercooler and the cold side. Any pics would be appreciated. I think I might need some of this to get the brain working.lol
Old Sep 6, 2011 | 11:39 PM
jgb454ss's Avatar
By the way its an 04 chevy fullsize and a trick performance turbo stage 3 on a 4.8.
Old Sep 7, 2011 | 03:53 AM
03sierraslt's Avatar
You havent tried the search button by chance have you? Maybe look for Trick turbo and install pictures. Something of that nature should work.
Old Sep 7, 2011 | 08:09 AM
jgb454ss's Avatar
I was on the search button all of last night, but the intercoolers on all the pics have the inlet/outlet on the sides and mine has both facing toward the front of the engine.
Old Sep 7, 2011 | 08:21 AM
Rick_Vor's Avatar
You could hit up Rick for some info.
Trick Performance Products
Old Sep 7, 2011 | 11:54 AM
TrickTurbo's Avatar
Truck Sponsor
Look inside the pipes usually I put arrows or numbers show the order. If they are not there, Try this out.
Once the turbo is mounted you will need to clock the compressor. Aiming downward.
• 90' black coupler aiming forward
• shortest leg 2.5 aluminum 90' connects to coupler the other leg is aiming down.
• 2.5 straight coupler.
• 2nd 2.5 aluminum 90' connect here. Routing this pipe
between the sway bar and frame. Now you will have the other end facing forward. Aiming into your intercoolers inlet.
• 2.5 silicone couple.
Inlet side complete.
Outlet side/ driverside.
• 2.5x3.0 black silicone.
• 3.0" aluminum 90' this has the blow off valve connection. Routing the pipe bewteen sway bar and frame. Bov is aiming towards passenger side.
• 3.0 x 3.5 this coupler will be in front of your powersteering pulley.
• maf
• 3.5 x 3.5 coupler
• 3.5 90 long leg Aluminum. Going to your tbody.
• 3.5 x 4.0 coupler at tbody.
Outlet side complete.
Let me know if you have any other questions.
Feel free to call.
940-781-5204
Rick
Old Sep 7, 2011 | 12:01 PM
charcold-bowtie's Avatar
Mine was like that
Link
Old Sep 7, 2011 | 03:09 PM
jgb454ss's Avatar
Thanks for the replies, got it sorted out.....Thanks Rick for the step by step write up.
Old Sep 7, 2011 | 03:43 PM
TrickTurbo's Avatar
Truck Sponsor
Your welcome. Thats what we're here for.
Old Sep 7, 2011 | 10:18 PM
jgb454ss's Avatar
Well guys got everything installed and ready to go. Just need to install the bigger radiatior and the 05 electric fans and wire them up. Hopefully I have some more time tomorrow or later on this week. All I can say is that Rick did a hell of a job with his kit, no problem whatsoever, everything fits like a glove. I was impressed.
Choda
Jan 22, 2026 02:03 PM
lxcoupe
Sep 6, 2017 08:24 AM
TAPyvehc93
Jul 23, 2017 10:54 PM
chvy=power
Sep 8, 2015 11:06 AM
slowswb
Sep 5, 2015 02:27 PM
