trick turbo ?
has anybody used the trick performance tubo setup. I am having trouble figuring out the placement of the intercooler and the cold side. Any pics would be appreciated. I think I might need some of this
to get the brain working.lol
Look inside the pipes usually I put arrows or numbers show the order. If they are not there, Try this out.
Once the turbo is mounted you will need to clock the compressor. Aiming downward.
• 90' black coupler aiming forward
• shortest leg 2.5 aluminum 90' connects to coupler the other leg is aiming down.
• 2.5 straight coupler.
• 2nd 2.5 aluminum 90' connect here. Routing this pipe
between the sway bar and frame. Now you will have the other end facing forward. Aiming into your intercoolers inlet.
• 2.5 silicone couple.
Inlet side complete.
Outlet side/ driverside.
• 2.5x3.0 black silicone.
• 3.0" aluminum 90' this has the blow off valve connection. Routing the pipe bewteen sway bar and frame. Bov is aiming towards passenger side.
• 3.0 x 3.5 this coupler will be in front of your powersteering pulley.
• maf
• 3.5 x 3.5 coupler
• 3.5 90 long leg Aluminum. Going to your tbody.
• 3.5 x 4.0 coupler at tbody.
Outlet side complete.
Let me know if you have any other questions.
Feel free to call.
940-781-5204
Rick
• maf
• 3.5 x 3.5 coupler
Feel free to call.
940-781-5204
Rick
Well guys got everything installed and ready to go. Just need to install the bigger radiatior and the 05 electric fans and wire them up. Hopefully I have some more time tomorrow or later on this week. All I can say is that Rick did a hell of a job with his kit, no problem whatsoever, everything fits like a glove. I was impressed.
Choda
Jan 22, 2026 02:03 PM
lxcoupe
Sep 6, 2017 08:24 AM
