Trick kit install
Old May 20, 2008 | 09:18 PM
charcold-bowtie's Avatar
Default Trick kit install
Been waiting to do this forever, finally got it done. Trick kit fit realy nice. Especially the hot pipes pieces, wastegate is vented to the downpipe and was a perfect fit. Thanks to everyone that answered all my dang questions. Few pics
My custom one off 45
Old May 21, 2008 | 12:23 AM
thunderwagen's Avatar
i cant tell very well from the angle of the picture, but make sure you have the turbo clocked so the oil drain is straight down.
Old May 21, 2008 | 12:34 AM
2005 Silverado's Avatar
SPAM HUNTER
How did you mount your intercooler exactly? Also...same as above...what is going on with your oil drain there?
Dustin
Old May 21, 2008 | 12:41 AM
kbracing96's Avatar
Dustin
Those are coolent lines guys, its a water cooled turbo Looks nice!
Old May 21, 2008 | 12:49 AM
SPAM HUNTER
Really?..but dont you still want the oil drain out the bottom?
Dustin
Old May 21, 2008 | 12:56 AM
kbracing96's Avatar
Dustin
The oil drain IS on the bottom, look harder!
Old May 21, 2008 | 01:04 AM
SPAM HUNTER
I dont see it...oh well...ill just trust you...and so are you just checking out the enemies kit installed...haha
EDIT!!!...i looked harder...ok...i see it now!
Dustin
Old May 21, 2008 | 01:48 AM
thanks kb, i ain gonna lie i wondered what the hell they were asking about. ON the turbo itself i assume i could tweak it a little more to fix the oil line, but the coolant lines do at some point become a problem.As far as the other fitting they are all downward and upward on the oil return, that was before we tweaked it and ran the line. The inter cooler is BOlted to the frame. Just remove the tow hooks and its easy.Its mounted about as far forward as possible. Wouls you like pics.....
Old May 21, 2008 | 07:18 AM
TrickTurbo's Avatar
Truck Sponsor
NIce install,, the turbos oil drain is aiming looks like at 4:30 to 5:00 if looking from the front. I see why you had to tweek the water lines.
Nice install Colton.
you should see that extension piece you requested today.
Rick
Old May 21, 2008 | 09:09 AM
SPAM HUNTER
Was your intercooler to big to mount it in from of the radiator?
Dustin
